Old 02-20-2007, 06:32 AM   #31 (permalink)
beyondspexj's Avatar
Member Number: 30264
Trader Rating: (30)
they are sold in pairs
beyondspexj is online now   Reply With Quote
Old 02-20-2007, 06:37 AM   #32 (permalink)
NeonDan's Avatar
Member Number: 138
Trader Rating: (69)
what i wanna know is how is it setup to differentiate between brake...parking light and turn signal
Built by experts. Tested in the real world.-Mopar
For sound Install/Tuning assistance: (727)512-9684 or PM
Now serving Upstate SC/N. GA SRT4 community
<---My modest 305fwhp "project" car in progress
NeonDan is online now   Reply With Quote
Old 02-20-2007, 06:59 AM   #33 (permalink)
SRT-4Store.com's Avatar
Member Number: 49032
Trader Rating: (18)
Dan:
The parking lights are at the center top. It's the single led, next half ring of 5, and the 3rd ring of 9(total 15 led's)
The brake/turn is the rest of the board.
Because of how the neon is wired from the factory, you cant seperate all 3 because the brake and turn signal is the same circuit. People have converted their cars to the "euro" setup where the brake and turn are seperate, and usually then end up using their reverse light section as a turn signal, but other than that, this is how it is.
Also, a few corrections:
1. BTR misquoted the price he paid($55 shipped)
2. That price was limited time for the units I had in stock. A new price will be given for any future releases(as they'll also be plug n play capable with a 3157 bulb base)
3. While BTR's procedure was fairly straightforward, i recommend the following steps:
- Preheat oven to 210degrees
- Please tails on cookie sheet, with the metal bolts facing down and lens facing up...NO TOWELS...fire hazard even if only in there for a few minutes.
- Allow tail light to bake for 10 minutes. This is long enough to get the sealant good and soft, but not long enough to damage the plastic of the tail light.
- Bake ONE at a time.
- The use of a buffer knife is ok here, but there is a black tar that DCx used to seal the tails up, I recommend a flathead screwdriver.
- Once you've got the board in there and its ready to go, you can just press the lens back in place until its locking tabs have reseated.
Again, this is just what I recommend...it's not the definitive way of doing things.
SRT-4Store.com is offline   Reply With Quote
Old 02-20-2007, 08:00 AM   #34 (permalink)
Lighting Modifications Moderator
haknslash's Avatar
Member Number: 21686
Quote: Originally Posted by SRT-4Store.com
hrm, wonder if you could get the Depo lenses...just the lenses
Nah, I tried that route from them back when I did those LED tails for everyone
They wouldn't budge
Would be ideal though
Old 02-20-2007, 08:49 AM   #35 (permalink)
Wheels & Tires Moderator
evo77's Avatar
Member Number: 1346
Can't you use a empty bulb base socket and solder the wires from the board into it that way you can just plug it into the stock harness? Wouldn't this eliminate the need for a resistor?
evo77 is online now   Reply With Quote
Old 02-20-2007, 08:55 AM   #36 (permalink)
Trader Rating: (18)
the resistor he was talking about is those big heavy ones used to control fast flash, but like i said, thats already been covered, no need to wire in one of those things anymore...
as for the empty bulb base, thats basically what figure releases will have already on them.
the bulb base has nothing to do with resistors...
Old 02-22-2007, 02:19 PM   #37 (permalink)
BTR
BTR's Avatar
Member Number: 11347
Trader Rating: (42)
You mean resistors to control fast flash?
tsk tsk tsk...keep up man, we've already covered that fix: CC and NiteHawk Present: The Flasher Relay Fix!
enjoy
I had no idea...
thanks for the info!
BTR is offline   Reply With Quote
Old 02-23-2007, 06:06 PM   #38 (permalink)
Trader Rating: (18)
hey BTR, you want to make your tails just plug in like normal?
go buy a couple empty 3157 bulb bases from autolumination, cut off the round part(youll understand what i mean and insert the wires in this order:
RED | WHITE ...........BLACK | (empty)
i also recommend soldering the ends of the wire so that they become solid instead of being individual strands(makes the bulb base stay on)
here's a pic to show you what i mean...ZukesSRT4 now owns this set of tails...
Old 02-24-2007, 11:35 PM   #39 (permalink)
SRTGavin's Avatar
Member Number: 4200
bump for the boards now coming with these, right!
CF Front Splitter from Swift Motorsports
IPP CF Hood
AEM Intake
3" ED Turbo-back Exhaust
ATP Pressure Pipe
Turbo XS RFL BOV
Turbo XS Wastegate
Turbo XS MBC
Mopar Stage 1
Mopar Stage 3 Coilovers
Mopar STS (w/booger bushings)
SRTGavin is offline   Reply With Quote
Old 02-25-2007, 09:08 AM   #40 (permalink)
BTR
BTR's Avatar
Trader Rating: (42)
cool, thanks for the heads up...
i'm waiting on some tint that I bought and I'll post pics when they are done!
Old 02-25-2007, 09:25 AM   #41 (permalink)
Trader Rating: (30)
well hurry up!!! lol
Old 02-26-2007, 09:38 PM   #42 (permalink)
Discussion/Performance Mod
NoisufnoC's Avatar
Member Number: 136
omgz!! i haz mods!!
NoisufnoC is online now   Reply With Quote
Old 02-26-2007, 09:53 PM   #43 (permalink)
EricP's Avatar
Member Number: 22154
bump for pic comparison to stock?
Stock Turbo
WHP:283 WTQ:334
EricP is offline   Reply With Quote
Old 03-01-2007, 09:14 PM   #44 (permalink)
Member Number: 45442
Hope to have some by the end of the weekend
Justins6s is offline   Reply With Quote
Old 03-08-2007, 03:52 AM   #45 (permalink)
Trader Rating: (18)
hey yall. just wanted to let ya know im runnin a groupbuy on these boards for those interested
http://www.srtforums.com/forums/showthread.php?t=337543
