Old 02-18-2007, 08:35 PM   #1 (permalink)
BTR
BTR's Avatar
Member Number: 11347
Trader Rating: (43)
Default HOW TO: Make your own L.E.D. taillights (for fiddy bux)...
Moderators feel free to move this to the how-to section when you see fit.
Ingredients
"Great Stuff, big gap filler"-5$
expired credit card-free
Led light board from srt4store-45$
optional...
acetone (if you make a mess)
step 1
put taillights in the oven (rest them on a towel so they dont melt) at 200 degrees for 5 mins at a time until they are soft enough to pry apart with a butter knife...
BTR is offline   Reply With Quote
Old 02-18-2007, 08:37 PM   #2 (permalink)
BTR
BTR's Avatar
Trader Rating: (43)
step 2
bust out the butter knife and pry around the taillights (at the connecting tabs) SLOWLY so you dont crack them...
Old 02-18-2007, 08:38 PM   #3 (permalink)
BTR
BTR's Avatar
Trader Rating: (43)
holy karp 60 seconds between posts?!?!
Old 02-18-2007, 08:48 PM   #4 (permalink)
BTR
BTR's Avatar
Trader Rating: (43)
Open sesame...
Old 02-18-2007, 08:51 PM   #5 (permalink)
BTR
BTR's Avatar
Trader Rating: (43)
test fit the led board into the housing and pull the wires through the hole
Old 02-18-2007, 08:54 PM   #6 (permalink)
BTR
BTR's Avatar
Trader Rating: (43)
pull the wires through...
Old 02-18-2007, 08:56 PM   #7 (permalink)
BTR
BTR's Avatar
Trader Rating: (43)
VERY IMPORTANT!!!!
wrap the wires around the screw at the back of the taillight so that the led board stays in place while you apply the great stuff. Or have your friend hold the other side while you spray it.
Old 02-18-2007, 09:01 PM   #8 (permalink)
BTR
BTR's Avatar
Trader Rating: (43)
Dont spray too much! b/c it will start coming out the other side!
Old 02-18-2007, 09:03 PM   #9 (permalink)
BTR
BTR's Avatar
Trader Rating: (43)
Shave the excess foam out with an old credit card...
Old 02-18-2007, 09:06 PM   #10 (permalink)
BTR
BTR's Avatar
Trader Rating: (43)
wait approx 3-4 hours for it to cure...
use the acetone on the stubborn foam that wont come off, acetone dissolves it with the quickness!
put the taillights back into the oven (AFTER the foam has cured for at least 8 hours) at 200 degrees and press them back together (you could also use a hairdryer for this step)
Old 02-18-2007, 09:08 PM   #11 (permalink)
BTR
BTR's Avatar
Trader Rating: (43)
Here is a pic with them on...
later on I'll apply the tint and show you how to wire them up with the resistor so they dont flash fast...
thanks for lookin!
Old 02-18-2007, 09:11 PM   #12 (permalink)
ToMuchBoost's Avatar
Member Number: 35620
Trader Rating: (78)
Good write UP! thank you, I'm going to have to do this.. Are they brighter then stock?
FYC Racing
Build Thread Here
ToMuchBoost is offline   Reply With Quote
Old 02-18-2007, 09:15 PM   #13 (permalink)
BTR
BTR's Avatar
Trader Rating: (43)
I'll post a comparison later
Old 02-18-2007, 09:15 PM   #14 (permalink)
AdvanSRT-4's Avatar
Member Number: 12791
Trader Rating: (57)
Nice write up Rich!
Old 02-18-2007, 09:17 PM   #15 (permalink)
Trader Rating: (78)
Sweet, thanks for taking the time to do the write up
Page generated in 0.18783 seconds with 13 queries
