Old 05-27-2005, 05:14 PM   #1 (permalink)
Dreamert's Avatar
Member Number: 1714
Trader Rating: (51)
Default How to hook up A/F gauge ?
REd wire: +12V
Black: to ground
Purple: to O2 sensor ?
Is that it ?
When I hook the black to ground and hook the red to +12v nothing happens but when I hook the purple to 12v I get a reading on the gauge......
Mopar A/F gauge that is
Dreamert is offline   Reply With Quote
Old 05-27-2005, 05:19 PM   #2 (permalink)
djgainsbond's Avatar
Member Number: 962
Trader Rating: (78)
You need to buy a single-wire Bosch 02 sensor from a local car place..($15).. it will have threads on it like a screw. You need to find a bung, which is a female bolt looking peice that will screw down onto that sensor.. ($5)
You need to have that bung welded above your cat, then screw the 02 sensro into it ($20 labor) then you run the signal wire from the guage to that single wire on the sensor, and ground your ground wire and find a 12v for your power wire.
EVEN A BROKEN CLOCK IS RIGHT TWICE A DAY
Quote: Originally Posted by noTe
You can use dish wash soap to wash a car.
Quote: Originally Posted by slow4dr
You can install your hot side pipe on my ass anytime.
www.myspace.com/djgainsbond Top Floor Ent.
djgainsbond is offline   Reply With Quote
Old 05-27-2005, 05:20 PM   #3 (permalink)
SRTforums Veteran
Kustomatix's Avatar
Member Number: 18578
Trader Rating: (112)
where are you putting the purple wire? just doing the red/black and no purple will get you nowhere. you have to have all 3 hooked up. do you have a new 02 sensor welded above your cat?
Kustomatix is offline   Reply With Quote
Old 05-27-2005, 05:31 PM   #4 (permalink)
Dreamert's Avatar
Member Number: 1714
Trader Rating: (51)
Not yet welded but I have a bosh O2 sensor that'll hook up in the place of the one in the cat for the moment being just to light my gauge till I get my new exhaust.
Old 05-27-2005, 05:34 PM   #5 (permalink)
SRTforums Veteran
Kustomatix's Avatar
the guage doesnt light up.....
Old 05-27-2005, 05:34 PM   #6 (permalink)
getnpsi's Avatar
Member Number: 14911
Trader Rating: (68)
a cat skews the readings. when you do your new pipes make sure your bung is before cat, if you have one still
2004 Black. SSTv1, Stage 2 with toys, 3" exhaust with cat, Slow4DR shifter, CBD vented hood.
WTT: CBD vortex generator for a w/i kit.
getnpsi is offline   Reply With Quote
Old 05-31-2005, 08:20 PM   #7 (permalink)
srt4bryan's Avatar
Member Number: 22385
yep mine is welded after the cat and its pretty much a light show
srt4bryan is offline   Reply With Quote
Old 06-01-2005, 02:00 AM   #8 (permalink)
SRT Videos Moderator
Lagzilla's Avatar
Member Number: 4098
Trader Rating: (26)
u ahve to buy a new o2 and get a bung put in, i just went to auto zone and got a bosch o2 forgot the part number but its on the boards somewer just keep looking
06 Honda S2000 Rio Yellow Pearl - K&N FIPK II
SOLD - 04 AEM EMS'd SRT
XBOX LIVE - "LawStudentLaggy"
Lagzilla is offline   Reply With Quote
Old 06-01-2005, 12:24 PM   #9 (permalink)
Dreamert's Avatar
Member Number: 1714
Trader Rating: (51)
Bosh: 11027
Page generated in 0.19559 seconds with 13 queries
