Here's how I installed my 35w Slim Ballast HID's & Relay Harness on my car. I'm not claiming this is the only way or the best way, just what I came up with.
Next, any of you who know me also knows my car is well kept & usually spotless but... this may be the dirtiest my car has ever been. It's still winter in Colorado so deal with it.
Tools you'll Need
8mm & 10mm sockets
Ratchet
Various size extentions (the longer the better)
10mm wrench
Torx bit screw drivers
Drill & drill bits
Velcro/ double sided sticky pads
Zip ties
Time Needed
This is assuming you take your time, zip tie & make a clean OEM looking install. If you're experiences with modding & electrinics it's not a problem. If you're new, it may take you a while to get it all sorted out. Don't rush, it's not a race. Remember-
If you didn't have the time to do it right the 1st time, you must have the time to do it right the 2nd time.
Experienced = 4hrs
Intermediate = 6hrs
Newbie = 8hrs
Getting Started
I'm assuming you all know how to take your bumper off (if you don't then theres plenty of good "How To's" on FMIC installs that detail the process). You don't have to remove it but it'll sure make things easier. I've got it down to about 35-45 minutes now. If it's your 1st time removing it, plan on 1.5 hours. This is also the step where you'll use most of the tools mentioned above.
Here's a quick re-cap:
(3) 8mm screws on the top
(5) 8mm screws on the bottom
(2) Torx screws per side to undo the fender well guards
(3) 10mm nuts per side securing the bumper to the fenders
Undo all the wires going to bulbs so you can lay the bumper to the side
(2) 8mm bolts per headlight to remove them
Undo all the wires going to bulbs so you can lay the headlights to the side
Relay Harness Wiring
Disconnect your negative terminal on the battery whenever you're working on electrical (it's not disconnected in the pic but trust me I did it when installing)
Lay out your Relay Harness & become familiar with what's going to where?
Run the wires loosly through the engine bay to get a feel for where things are going, how they're getting there, & how you're going to secure everything.
Positive wire
Relay mounted above Transmission/ BOV area
Driver's side wires pulled through through opening
Passenger side wires ran across
HID Ballasts
Start scoping out where you're going to mount your ballast. I've seen lot's of people put them in the fenderwells but they are exposed to lost of grime, weather, abuse there. Even though they are weatherproof, they're still electronics. I've also seen them put in the engine bay but again the heat could reduce the lifespan of the ballasts.
There are 2 really good locations in my opinion which will stay cleaner then the fenderwells & cooler then the engine bay. They will still see their dose of each but I feel they are a nice compromise.
#1 Behind/ under the headlights
#2 Above the front mount intercooler's mounting points
I'm putting the headlight ballasts in location #2 as I'm going to put the ballasts for my fogs in the #2 location on down the road. Choose whichever one suits you best.
Now you need to determine what method you're going to mount them with. Many kits come with metal "T" brackets, double sided sticky foam or rubber pads. Many ballast also have holsse for securing with screws or bolts. I chose Velcro which may seem wierd but I need something not so permanent due to my switching out ballasts to test & trying different ones all the time so this is easist for me. Again, choose whatever you're comfortable with.
Industrial Strength Velcro available at Lowes / Home Depot
Cut out the sizes you'll need & secure them to the ballast & igniters (little boxes 1/2 way along the wires).
