Ok so i didn't see a HID fog light install anywhere "forgive me if there is one", so i decided to take some pictures during my install. Granted it is pretty easy, but it should help some people out.
So here is how it came in the mail
Hid bulbs, ballasts and the relay with all the wiring and fuse. This way you can power the Ballasts right off the battery, rather than stock wiring.
So the 1st thing you want to do is jack the car up off the ground. Crawl under the car and locate the factory clip going to the bulb, and unplug that.
Next pull out the factory pos bulb. Lefty Loosey.
Next install the HID bulb. Be very careful not to touch the bulb with your fingers or anything else for that matter.
Righty tighty.
Position the ballast where you want to mount it. You dont have many choices if you have the stock intake like myself. I just mounded it on the factory air-box.
Run the wires from the ballast down to your newly installed HID fog light, and attach them.
I used Molding Tape from Murrys to attach the ballast to the air box.
Here it is mounted.
To be continued after work today. It started to rain after i got that far.
