02-20-2006, 12:17 PM
#1 (permalink )
Member Number: 30760
How do I stop led turn signal fast blinking?
Can someone point me in the right direction to stop my turn signals from blinking so fast because of my led signals?
I know I need a resistor but where do I find it? and how much?
Any vendors on here sell them?
Can someone give me a direct link?
thanks
02-20-2006, 12:33 PM
#2 (permalink )
Member Number: 18242
im building one right now as my LED front signals hyperblink
02-20-2006, 12:41 PM
#3 (permalink )
Member Number: 7655
You should be able to buy flasher relays designed for LED's, I just have yet to find a place that sells them.
02-20-2006, 12:53 PM
#4 (permalink )
Member Number: 12791
Here's The ones I used...You need one on each side.
Link:
http://autolumination.com/equalizers.htm Scroll down to see Them.
ASE Certified Automotive Technician
02-20-2006, 12:58 PM
#5 (permalink )
Member Number: 11347
Quote: Originally Posted by AdvanSRT-4
which ones did you get?
02-20-2006, 01:55 PM
#6 (permalink )
Member Number: 29215
Watching for answer, that place is close to me
02-20-2006, 02:09 PM
#7 (permalink )
Member Number: 20279
All that this is is a 12 cent resistor in a fancy aluminum casing. You just need to find the right value resistor and splice it in.
02-20-2006, 02:17 PM
#8 (permalink )
Should be 6 ohm.
02-20-2006, 02:44 PM
#9 (permalink )
Member Number: 7655
that resistor and fancy casing get pretty damn hot. I'd rather keep mine in a casing rather then in the open.
02-20-2006, 03:20 PM
#10 (permalink )
I doubt there's much of a heat issue. Unless you're 86 years old and drive with your blinker on nonstop. Heat shrink tubing is just as weather proof.
But I think most of my problem is with autolumination as a company. I just can't help but to bag on their stuff.
02-20-2006, 05:17 PM
#11 (permalink )
Member Number: 37899
I got 2 of the 6-ohm, one for each side, and havent had any problems with them...easy to install
((JESUS)) Salvation is found in no one else, for there is no other name under
heaven given to men by which we must be saved.- Acts4:10,12
02-20-2006, 05:21 PM
#12 (permalink )
where can you find a 12 volt resistor for 12 cents?
02-20-2006, 06:36 PM
#14 (permalink )
yeah but are those 12 volts?
02-21-2006, 12:02 AM
#15 (permalink )
yes i finished mine today 6ohm got a pack at radio shack (needed some 6ohm anyway for a autostart install) works fine
Linear Mode
» Site Navigation
> Other Vehicles
» Network Links
