HOW TO: Bake Open Stock Headlights - Page 3 - Dodge SRT Forum
post #31 of 68 (permalink) Old 05-24-2010, 05:10 AM Thread Starter
2011 Calendar Car
SRT of the Month
Quoted: 0 Post(s)
Damn! I know some of the non-Depo aftermarket oem-style lamps are really tough. I can't remember the specific brand, but there's one that's nearly impossible to crack open.
RIP Jon Timko 1981-2011
wiggy is offline
post #32 of 68 (permalink) Old 05-25-2010, 02:27 PM
EthansSRT-4's Avatar
Quoted: 1 Post(s)
i have stock ones and i couldnt even get the screwdriver through the glue they use. it was still to hard! lol
"If winning doesnt matter, then why do they keep score?"-unknown
Mods--DSP, 3 Bar Map&Tip, CAI, fuel pump rewire, 8k healights, 3k foglights, bfmic, jmb colside with Tial BOV, catch can, boomba check valve, scan gauge pro, wideband, oil press, 3" catless turbo back exhaust, granetelli wires, motor mount inserts, NX 75 shot, dynotune 2 stage RPM window switch, intercooler sprayer. thats all for now!
EthansSRT-4 is offline
post #33 of 68 (permalink) Old 05-29-2010, 09:17 AM
Super Moderator
SRT of the Month
2011 Calendar Car
LilSparkPlug's Avatar
Quoted: 0 Post(s)
Originally Posted by EthansSRT-4 View Post
thanks wiggy, i tried everything and it would not budge at all! it was black sealant. i tried butter knife, small screwdriver, big screwdriver, 2 screwdrivers lol i just ended out cutting it. the lens was in the over so much even at 250* is started to crack me lens
The cracking is why I'll never do a stock set again. Happened to my SXT's retros.
LilSparkPlug is offline
post #34 of 68 (permalink) Old 05-29-2010, 10:03 AM Thread Starter
2011 Calendar Car
SRT of the Month
Quoted: 0 Post(s)
Yeah, the stock lamps aren't worth the effort IMO. Depos come apart with so little work that it makes it totally worth it to just splurge on a set if you're trying to do a retro.
wiggy is offline
post #35 of 68 (permalink) Old 05-29-2010, 11:30 AM
Super Moderator
SRT of the Month
2011 Calendar Car
Quoted: 0 Post(s)
And it's always best to have stockers as spares
post #36 of 68 (permalink) Old 05-30-2010, 12:10 AM
Quoted: 1 Post(s)
how much are depos? where can i get a good set of depos? my stockers came out really good after cutting it and it is sealed nice and tight no water seapage after 2 rain storms and a car wash! lol
post #37 of 68 (permalink) Old 05-30-2010, 07:24 PM
Super Moderator
SRT of the Month
2011 Calendar Car
Quoted: 0 Post(s)
Depos on Modern Performance, black housings on Ebay.
post #38 of 68 (permalink) Old 05-31-2010, 08:57 AM
isthatguy's Avatar
Quoted: 0 Post(s)
i didnt have any issues with my stock headlights... the first one took me a few minutes. had to figure out the best place to pry the butter knife, I literally got the second headlight apart in less than 1min after I had baked it.
04 srt4 built, crane 18, pte 6262, ragetek extended input shaft 448/412 pump
05 mustang gt, comp thumpr stage 2 cams, pypes full exhaust, roush intake, hurst STS, FRPP 4.10 gears, and a supercharger sitting in the garage.
isthatguy is offline
post #39 of 68 (permalink) Old 05-31-2010, 09:01 AM
Quoted: 1 Post(s)
if mine ever leak or i get tired of the look now i know where to go! thanks!
post #40 of 68 (permalink) Old 06-06-2010, 03:07 AM
Legoman's Avatar
Quoted: 0 Post(s)
PLUS (even DOUBLEPLUS): the mountings for the reflector bowl are different. You cannot use the stock plastic pieces for a professional retrofit with that mounting plate and actual bi-xenon lenses!
Legoman is offline
post #41 of 68 (permalink) Old 06-06-2010, 12:19 PM Thread Starter
2011 Calendar Car
SRT of the Month
Quoted: 0 Post(s)
??? Not sure what you mean. The lamps that I've used have had no issues with swapping parts. In fact, my retros are OEM housing with Depo bowls and lenses.
wiggy is offline
post #42 of 68 (permalink) Old 06-06-2010, 01:59 PM
Legoman's Avatar
Quoted: 0 Post(s)
i mean those little plastic snappers that sit on the ball-ish mounting points and holt the bowl.
OEM = 1 piece, Depo = 2 pieces and they snap directly into the 13mm hole in the hid-mounting plate.
Legoman is offline
post #43 of 68 (permalink) Old 11-27-2010, 02:31 PM
Quoted: 0 Post(s)
alright i been trying to get these headlights open for the last 40 min...i cant get anything threw the glue, it just seems to like kinda chip... any suggestions?
kamakazi_lunatic is offline
post #44 of 68 (permalink) Old 11-27-2010, 04:59 PM
isthatguy's Avatar
Quoted: 0 Post(s)
i used a butterknife.
post #45 of 68 (permalink) Old 11-27-2010, 08:28 PM
Crazyced's Avatar
Quoted: 157 Post(s)
Mine took forever to open. Cut as much glue as you can with an X-acto around the spot you are going to pry (under the flasher was the best for me) then pry hard using 2 screw driver (starting by twisting a big flat screwdriver at the edge worked best for me). Once you get one completely in, work your way around with the other. Once you pried it enough to get your fingers in, just split it open with your hands.
That's how I did mine. the black housing lip took a beating from the prying though.
Crazyced is offline
User Tag List
Linear Mode Linear Mode
