Old 09-29-2009, 02:02 AM   #1 (permalink)
BoostedPDX's Avatar
Member Number: 28038
Default Higher watt bulb?
Im just wondering if anyone has used the nokya 80/100w bulbs in their car, how long and if they had any wiring issues. if anyone is using a different bulb with a higher wattage then stock please post the brand, watts, and how long you have been using them..
thanks!
1998 Plymouth Neon. Stock
2004 Silver Srt-4 Slightly Mod'd (Sold)
1999 R/t Fully built s16G Turbo. / Show. (Sold)
BoostedPDX is offline   Reply With Quote
Old 09-29-2009, 07:10 AM   #2 (permalink)
SRT of the Month
LilSparkPlug's Avatar
Member Number: 17636
Trader Rating: (70)
I can guarantee you you'll have wiring issues if you use those. The harness isn't meant to carry that wattage. It may not happen right away but it happened to my friend Dan's SRT in a matter of four months....wiring melted and the MFS switch died on me while I was driving it...in the middle of a blizzard.
Old 09-29-2009, 02:02 PM   #3 (permalink)
BoostedPDX's Avatar
Ya i have had higher watt bulbs in my 99 neon and had to wire in a relay system to keep it from melting the plugs. i guess im just curious as to what others are using. other then HID. I heard a couple people mention the nokya bulbs but not what wattage they are using.
Old 10-10-2009, 09:15 PM   #4 (permalink)
Member Number: 23796
Hmm I just ordered those nokyas with my new headlights... maybe I won't use them if they are going to fry something. Shouldn't it be pretty easy to make relays for them?
ElGringoLoco is offline   Reply With Quote
Old 10-10-2009, 09:28 PM   #5 (permalink)
SRT of the Month
Trader Rating: (70)
Buy one from theretrofitsource.com
Old 10-15-2009, 08:12 PM   #6 (permalink)
PERFORMANCE HEADLIGHT HARNESS XENON BULBS
Any idea if these will work for an 80w? I am under the impression that they won't do anything, but figured I would ask before I dismissed them completely.
Old 10-16-2009, 08:42 AM   #7 (permalink)
SRT of the Month
Trader Rating: (70)
Technically it's not the just the socket that needs to be upgraded, it's the entire harness starting from back where the headlight wiring draws it's initial power from.
Old 10-22-2009, 01:57 AM   #8 (permalink)
Miotu's Avatar
Member Number: 43014
dont use the high wattage bulbs, the blue ones i had before where 70 watts and 6 months later no headlights at 1 in the morning....
No amount of HP and torque can make up for a bad driver
Then: stock .164 r/t 2.143-60', 13.69 @100.9mph
Now: Mopar stage 2 w/o toys, CCA bfmic, 3" injen intake, TWM performance sts, custom 2.5" see w/catless dp, Hks ssq (newstyle), hot and coldside hard pipes, Ghetto ass I/C sprayer, full kicker system, 2 RF punch p2s in the RF box powered by a Alpine vpower 1000 watt amp, kenwood excelon kdc-x991
Miotu is offline   Reply With Quote
Page generated in 0.14409 seconds with 13 queries
