Old 02-11-2007, 02:25 PM   #1 (permalink)
Member Number: 22556
Default HID'S turn on all the time - Any Help
I have an 04 SRT4 and i just installed the Xenon 6000K HID kit in the car. Its a Plug N Play kit that goes into the factory harness. Everything works great when the car is of, but as soon as i turn the ignition to the on position the HID's turn on. The headlight switch does not control the lights when the car turns on. Does anybody have this problem??? I have searched for anybody posting such a problem but no luck. What am i missing?? Any help would be great. Thanks in advance.
Turbo-Toy is offline   Reply With Quote
Old 02-11-2007, 02:42 PM   #2 (permalink)
Member Number: 47115
Trader Rating: (28)
are the signal lights (little ones next to the headlight) also on when you turn the ignition on?
satyr is offline   Reply With Quote
Old 02-12-2007, 12:17 AM   #3 (permalink)
No the signal lights do not come on. However the fog lights do turn on.
Old 02-12-2007, 04:14 PM   #4 (permalink)
Trader Rating: (28)
not exactly sure..probably a bad MFS though (multi function switch).
our cars seem to have lots of trouble with them
Old 02-14-2007, 02:06 PM   #5 (permalink)
Thanks for the input man but i found the problem. Its my DRL module, i had to get a bypass relay & resistor combo for each side of the headlights. It taps in the factory harness lines for Low Beam and tricks the computer.
Picked up both of the kits last night. I will be installing them soon. Way too cold here now.
Old 02-14-2007, 02:18 PM   #6 (permalink)
scottw03's Avatar
Member Number: 23435
Trader Rating: (39)
I was going to say where are you located? I am assuming Canada since the US models didn't have DRLs.
scottw03 is online now   Reply With Quote
Page generated in 0.14565 seconds with 13 queries
