Old 06-02-2009, 11:44 PM   #1 (permalink)
Member Number: 68799
Default hids/ fuses
hey i installed my h-10 hid kit in my fog lights tonight and i keep blowing the fuse . i blew 2 fuses. its a 10 amp fuse. so than i ran out of 10 amps and only had a 20 amp and put it in there. but im afraid im gonna fry the wires.. has this happened to anyone with blowing fuses?
halokid117 is offline   Reply With Quote
Old 06-03-2009, 08:36 AM   #2 (permalink)
-ND4SPD-'s Avatar
Member Number: 458
Trader Rating: (46)
2 things, the neon SRT uses an 880 bulb style for the fogs (all other SRT's use H10).
This is why you really should use a relay harness to prevent issues with blowing fuese etc. The factory wiring wasn't meant to carry the type of load the ballast create upon initial fireup (23,000v & 15a each). A relay harness is $25 -$30. Replacing fried wiring is gonna cost a lot more, I can guarantee it!
John Ruckman
Stage 3 with all the goodies
See My Ride
ND4SPD DESIGNS
Old 06-03-2009, 10:08 AM   #3 (permalink)
Default .
so if i buy a relay it will work ? ... also do u think i will need a relay for the headlights?
Old 06-03-2009, 11:48 AM   #4 (permalink)
wiggyx's Avatar
Member Number: 58107
Trader Rating: (51)
You need a relay for ANY HID kit, not just fogs.
wiggyx is online now   Reply With Quote
Old 06-03-2009, 05:36 PM   #5 (permalink)
Default .
no wat im sayin is i need to get 2 relays ? one for fogs one for headlights ? or they both can plug into one?
Old 06-04-2009, 12:35 AM   #6 (permalink)
-ND4SPD-'s Avatar
Member Number: 458
Trader Rating: (46)
Yes, a relay harness for both head & fogs (2 relay harness's total).
Old 06-06-2009, 10:34 PM   #7 (permalink)
Default 20 amp
has anyone put 20 amp fuses in there fog lights and it worked fine?
Old 06-06-2009, 10:35 PM   #8 (permalink)
BrandynSRT's Avatar
Member Number: 63412
Trader Rating: (24)
thats a bad idea
BrandynSRT is offline   Reply With Quote
Old 06-07-2009, 12:48 AM   #9 (permalink)
whiteSRT69's Avatar
Member Number: 70066
ha im gonna get bashed for this
i just upgraded from 10 to 15. i have had HID's for over a year now with no problems
no relays and still goin strong!
Stone White on White rims =
whiteSRT69 is offline   Reply With Quote
Old 06-07-2009, 02:43 AM   #10 (permalink)
wiggyx's Avatar
Trader Rating: (51)
That may be, but it's still not a good idea. When your multi-switch goes, you will change your tune.
Old 06-07-2009, 02:57 PM   #11 (permalink)
Silverbullet114's Avatar
Member Number: 47454
No relays here. Popped 10 fuses at first it was a bad ballast contacted the seller and he replaced the bad ballast 5 months and nothing, but pure 6k & 4k action
"It's All About Reputation"
Silverbullet114 is online now   Reply With Quote
Old 06-07-2009, 03:20 PM   #12 (permalink)
BrandynSRT's Avatar
Trader Rating: (24)
i still cant believe ppl dont run a relay... that multi function switch and wiring wont hold up for to long
Old 06-07-2009, 07:25 PM   #13 (permalink)
whiteSRT69's Avatar
ive had mine going for 14 months with about 3-4 hours of use at night and nothing wrong here! everything works fine!
Old 06-07-2009, 08:06 PM   #14 (permalink)
wiggyx's Avatar
Trader Rating: (51)
You could theoretically play Russian Roulette forever too, but that doesn't mean that it's a good idea. Basically, you're taking a gamble. The fact that it works now, doesn't mean that it will work in 12 months, 1 month, or even 1 week.
Old 06-07-2009, 08:56 PM   #15 (permalink)
whiteSRT69's Avatar
i understand the risk im playin with it. ive actually looked into getting some relays just really never thought of it since its been so long with very little problems its been going good and to me HID's are getting old. ive been thinkin of putting normal bulbs back in and sellin them off
Page generated in 0.18652 seconds with 13 queries
