Old 04-07-2008, 11:49 PM   #46 (permalink)
resek's Avatar
Member Number: 37756
Quote: Originally Posted by nemisis View Post
try pulling out fuse #5 on the side panel. i accidentally clicked my hi beamwith a stock bulb and the hid still wired in and the fuse blew. you get lows and fogs but no hi's and drls. with the hids you won't need the hi's anymore at least with mine i never did once i got the hid kit.
it's a RETROFIT ...
not poor halogen hid kit.
plus, we paid for a bi-xenon projector (Acura TL), cause we wanted the quality and highbeam modes.
Nikon D40
Canon A590is
Old screen name : jfcampeau.
resek is offline   Reply With Quote
Old 04-08-2008, 09:57 AM   #47 (permalink)
Viper Jr's Avatar
Member Number: 3756
Trader Rating: (19)
Looks like the relay didn't fix it.
I need to provide similar resistance on the circuit as a headlight would.
Will let you guys know when I get things resolved. I'd love to get another connector for the passenger side so I don't have to use my hacked up bulb. Anyone know where I can find one?
Viper Jr is offline   Reply With Quote
Old 04-08-2008, 10:03 AM   #48 (permalink)
Member Number: 14212
viper ask boostjunkie if has any spares, u could tell him to throw em into my box. my headlights ship friday.
hope u figure this out or else i might have to run a stand alone switch for the headlights too.
Frosty is offline   Reply With Quote
Old 04-08-2008, 10:40 AM   #49 (permalink)
Scammer
BoostJunkies's Avatar
Member Number: 50062
Trader Rating: (25)
need another set of relays?
BoostJunkies is offline   Reply With Quote
Old 04-08-2008, 11:06 AM   #50 (permalink)
resek's Avatar
So bad, snif snif.
Viper, is your high beam working correctly with the headlight switch inside ?
Old 04-08-2008, 11:12 AM   #51 (permalink)
resek's Avatar
Quote: Originally Posted by sschung View Post
i just mailed you some pics of my setup.
sschung, can you mail this picture to me also please, that would be appreciated !
Old 04-08-2008, 12:17 PM   #52 (permalink)
resek's Avatar
can this help a little bit ?
Are you making your custom harness like this boost ?
Old 04-08-2008, 12:19 PM   #53 (permalink)
if u have any lying around could u throw em in my box pleaseee
Old 04-08-2008, 12:58 PM   #54 (permalink)
resek's Avatar
Hey dude, i'm in search of info on hidplanet forums.
Maybe someone already found the answer to our problem.
i found that
Quote: Originally Posted by drew76
I'm attempting my first retrofit using E46 single xenon projectors wich I purchased here through HID planet. Car is 2004 Dodge SRT-4 canadian with DRL's.
I've soldered up my wiring harness and I think everything is okay but I'm having problems getting everything to work while retaining the normal function of my DRL's.
I did the continuity/voltage tests and determined that my car is positive switched. I triggered my relay off the stock headlight connectors low beam terminal. My HID's worked fine but I had no DRL's.
In my car, the DRL's are the foglights. The DRL's are on whenever the ignition is on. It doesn't matter wether the e-brake is on/off or if the car is in gear. The DRL's turn off with the low beams. They can be reactivated with the low beams on using the stock foglamp switch, but turn off automatically when the high beams are turned on.
Basically almost all of the lights are hooked up through 2 DRL relays, then go through the stock multifunction headlamp switch. Looking over factory wiring schematics, it seems that the high beam circuit is the simplest and least affected by the DRL relays.
Right now, I have my wiring harness relay being triggered off of the high beam terminal at the driver side headlamp. The hid's function normally but of course i have to use the high beam setting. The only way I could get the DRL's to work normally was to put a stock 9007 halogen bulb in the passenger side connector. I've cut off the high beam pin inside the bulb so that it doesn't light up with the projector's. What is strange to me is without that bulb plugged in, I have no DRL's. Either way the HID's seem to be unaffected.
If anyone could offer some insight it would be greatly appreciated. This is a great site with lots of helpful info, I've spent alot of time here learning and have been wanting to do a retro for some time now.
Thanks
I know, we already knew it, but it seems that someone from here had the same problem.
Old 04-08-2008, 02:08 PM   #55 (permalink)
Scammer
Trader Rating: (25)
Yup, thats the same way I do it.
Old 04-08-2008, 03:54 PM   #56 (permalink)
resek's Avatar
Ok !
So i guess for now, the only way to solve this problem would be to put a "dummy light" into the other un-use socket ...
I think that sschung used this way ...
Old 04-08-2008, 04:18 PM   #57 (permalink)
resek's Avatar
I recently got a HID retro kit and got everything all wired in (using a relay and separate power for the HID's)
Unfortunately I am having some problems, I am in Canada so the fog lights come on when the car starts as Daytime Running Lights (DRL).
Well since the HID's are installed the fogs don't come on when the car starts... The HID's do. Regardless of the headlight switch position.
If the car is off, all the lights function properly (go on and off via the switch)
If I plug in a stock headlight bulb, the fogs come on properly when the car starts and all is good.
I have an adapter which plugs into one of the stock headlight harnesses which is what runs the relay turning on and off the HID's It is only using 2 of the 3 wires for the relay (2 seem to be ground and 1 is power)
I looked in the service manual to see if I could figure out how the DRL's are wired in but it didn't even show the fog light circuit, only the headlights.
Any ideas on how I can fix this issue? It's a real PITA as the HID's come on right when the car has just started and sometimes stalls the car.
Help Please...
I wouldn't mind not having DRL (fogs on for day light) ...
But i don't want the HID to get on when i start the car. If i want to put them on, i want to do it by myself with the toggle switch inside.
I don't really mind about fogs, i just can run a 2nd switch inside my car and put them on by pressing it.
A switch like a switch you have in your house to open the light.
Old 04-09-2008, 05:24 AM   #58 (permalink)
the 2nd switch is very easy to do. i am thinking of doing the same
Old 04-09-2008, 05:28 AM   #59 (permalink)
i dont understand why the headlights turn on though. if using a relay what is completing hte circuit?
so turning on the headlights is a positive switch? it triggers the relay and completes the circuit?
Old 04-09-2008, 11:13 AM   #60 (permalink)
Member Number: 21041
just use a dummy bulb or something else that will put LOAD on your second connector. it's so fricken easy i don't see why this thread is at 4 pages. you get all the same functionality of stock and don't have to buy another switch or crap.
05 black srt-4
95 purply neon
87 rusty 200sx
sschung is online now   Reply With Quote
Page generated in 0.22370 seconds with 13 queries
