Old 02-26-2007, 02:39 PM   #1 (permalink)
jyndrus90's Avatar
Member Number: 22464
Default Hid relay
Well I bought it off here and one came do i need 2? It has blue, yellow,black white and red wires. I know red is to battery it has a big fuse. How do i hook these up?
GT3076r at 18/22psi varying Stage 2 SCT RC650cc
Walboro 255 3" dump NDE TCS AGP Returnline TurboXS MBC AGP Hardpipe w/ HKS Maddog STS Tein SS AGP MM's Aeroforce Tech Gauge AEM Wideband SB STG 3 clutch
jyndrus90 is offline   Reply With Quote
Old 02-26-2007, 03:30 PM   #2 (permalink)
endlessheart666's Avatar
Member Number: 36526
Trader Rating: (30)
You should only need one. It should have plugs for both ballasts plus plugs that go into the stock harness. It goes inbetween the harness and ballast...has one(or sometimes two) grounds and one(or sometimes two) positives to connect to the battery.
97 Miata Turbo
endlessheart666 is offline   Reply With Quote
Old 02-26-2007, 04:20 PM   #3 (permalink)
Member Number: 47115
Trader Rating: (28)
regarding this same thing..I also ordered one of these.
it has conections for each ballast and one to the oem headlight plug..however my HID kit has two oem adapters, so which do i Plug it into? and which plug from the actual HID kit do I use? Do I put one into the relay harness and one into a factory headlight plug?
Also, being 9007 bulbs they have two bulbs with it, one HID (lows) and a halogen HI, i'm not sure how to hook the wires up.
i'm going to make my own thread with a diagram of what i'm talkign about in a few hours.. but any help is wanted.
satyr is offline   Reply With Quote
Page generated in 0.13348 seconds with 13 queries
