Old 09-21-2009, 05:33 PM   #1 (permalink)
YoNkErZsRt4's Avatar
Member Number: 43878
Default HID question
I new to HId's with this car, I'm curious if the the stock headlight lens cN hold up to the heat of the hid bulb? And how easy is to install the kit on these cars? I did a evo and it was a little different
YoNkErZsRt4 is offline   Reply With Quote
Old 09-21-2009, 08:34 PM   #2 (permalink)
Zero_psi's Avatar
Member Number: 71591
yahh it will hold up just fine even if u do 55 watters insatll is the same plug and play
stage 1 with some other goodies
Zero_psi is offline   Reply With Quote
Old 09-21-2009, 08:49 PM   #3 (permalink)
fivetoez's Avatar
Member Number: 9691
An HiD bulb actually runs cooler than Stock bulbs.
_____5TOEZ______ 1967 Cadillac Calais 429 2dr., 1967 Chevelle 4sp. Conv. ,1978 Dodge 318 "Factory Custom"van., 2004 Dodge Srt-4,Stage1.5(E-Blue) & a couple motorcycles.
Old 09-22-2009, 06:07 PM   #4 (permalink)
Good to know....see ya learn something new everyday, I guess the real risk is the watts, from what I read we need a relay
Old 09-22-2009, 07:20 PM   #5 (permalink)
Member Number: 75272
relays are used to xtra protection so that the ballast doesnt try to use as much power from the stock harness
eskalaid is offline   Reply With Quote
Old 09-23-2009, 02:49 AM   #6 (permalink)
Member Number: 70979
you will be fine with the HID kit, all cars can hold up the HID kit...even the deep blue color (10,000), and its very easy to install, just find a place to put the ballast under the hood and the rest its very easy.
junior_x is offline   Reply With Quote
Old 09-23-2009, 03:01 AM   #7 (permalink)
Colin1337's Avatar
Member Number: 55514
so assuming this is right, that means it would be safe to run them in the Depo projector headlights?
2005 SRT-4
Stock PCM, DSP w/PTP canned tune, FW WGA, ED SEE, BFMIC, Mopar Rice Plate, Injen SRI, DCR 180 thermo, Granatelli Plug Wires, 4306 NGK plugs, V-band exhaust manifold.
Soon to come:
PTP S3K and supporting fuel mods
Colin1337 is online now   Reply With Quote
Old 09-23-2009, 11:20 PM   #8 (permalink)
l
ummm no ur depos have shitty projectors so one you put an hid blub in it the beam spread will be horrible and it would do u justice . so i wouldnt as far as the other guy saying u can support 100000 k dude u cant get what ever color temp u want its the blub size that matters,but anything above 8000 k wont help u see any better . the higer the temp the less output
Old 09-25-2009, 11:30 AM   #9 (permalink)
Doppleganger's Avatar
Member Number: 69247
You would be best to run D2S burners with the H7 adapter rings in the H7 projector housings. They'll adapt best to HID. That's what I'm planning to try out, and then probably do the right thing and put some proper HID projectors in there.
HID in the stock reflector housings suck. Very few headlights adapt well, and usually scatter way too much light to be safe. Aiming them down does nothing to help with that, too.
I also recommend sticking with 4100-4300K color temp. You'll get the most usable light on the road. The big difference is on wet roads. 6000K and up color temps really wash out when the short-wavelength light scatters when it hits the water on the road.
Doppleganger is offline   Reply With Quote
Old 09-25-2009, 11:33 AM   #10 (permalink)
And, if you want that "blue" color, just mod the shield (usually just ever-so-slightly bending it backwards towards the burner (bulb) maybe 1-2mm) to get more color in your cutoff.
This is what the cutoff looks like in the Bosch e46 single projectors in my WJ:
Old 09-28-2009, 09:34 PM   #11 (permalink)
Psyop's Avatar
Member Number: 74857
So HIDs can be done with say the mpx halos? And are you referring to the s2k HID setup (D2S)? Someone said because the way it projects out it wouldnt scatter and blind as bad. Dont tell me I cant do HIDs with the mpx halos please lol.
Psyop is offline   Reply With Quote
Page generated in 0.17969 seconds with 13 queries
