Old 02-03-2008, 03:18 PM   #1 (permalink)
Member Number: 46915
Trader Rating: (15)
Default HId only working on high beams
Whats the trick to make it working?
When i put my lights on, on low beam, there's nothing working but on high beams they are lightning up!
What the fuck
05 stone white
sr-tom is offline   Reply With Quote
Old 02-03-2008, 04:12 PM   #2 (permalink)
Falbz's Avatar
Member Number: 22294
Trader Rating: (80)
Are you running a relay harness cause sometimes the generic ones cross the wires by mistake when they mass produce them????
Its really easy to fix and all you have to do is splice the high beam wire with the low beam one and vice versa. Try searching for an hid install or something and just look for the colors again. Theres only 3 wires so its really easy to find the two you need.
Basically the high beam wire has the power right now so all you need to do is splice it into the low beam wire and you should be all set.
Falbz is offline   Reply With Quote
Page generated in 0.15839 seconds with 13 queries
