06-25-2007, 08:06 AM
#1 (permalink )
Member Number: 23802
Hid Install!
does anybody have an hid how to install guide or atleast know were I can get 1.
06-25-2007, 08:10 AM
#2 (permalink )
Member Number: 40796
It is extremely easy, did you buy a plug 'n play kit?
06-25-2007, 08:23 AM
#3 (permalink )
yea but lol dont have a clue what to do
06-25-2007, 08:32 AM
#4 (permalink )
The plugs should match up to each other.
Decide where you want to put the ballasts. Make sure the wires won't be rubbing on anything when installed.
Make your connections, again check for any clearance issues
insert bulb into headlght, make sure everything works. and your done.
If you want I'll take some pics for you when I get a chance
06-25-2007, 08:38 AM
#5 (permalink )
thanks man i would appreciate that.
06-25-2007, 11:27 AM
#6 (permalink )
Lighting Modifications Moderator
Member Number: 21686
I
HIGHLY advise against installing a plug and play kit without using s upgraded relay harness.
Do not simply plug the kit straight thru your stock wiring unless you like burnt toast and marshmellows
Search around and you'll understand why
06-25-2007, 02:35 PM
#7 (permalink )
Member Number: 46113
GET the RELAY harness !!!!!!!!!!
06-25-2007, 06:29 PM
#8 (permalink )
Member Number: 52716
I have a 8000k headlight and custom made 8000k fog light kit with no probs. I've had for a while. Sometimes better to be safe than sorry though.
06-25-2007, 07:02 PM
#9 (permalink )
Its a ticking time boomb man !!
06-25-2007, 07:13 PM
#10 (permalink )
Alright you've talked me into it. Where do I get it and how do I install it. Hopefully no cutting/splicing.
Schwitzer/Borg Warner S362,DNP Manifold,AEM EMS,TialV44 WGA,AIS fmic,DSS stg5 Axels,Meghans Coilovers+more.
06-25-2007, 07:38 PM
#11 (permalink )
ebay or a vender here sells it..
Search for HID relay and you will get pics
06-25-2007, 07:48 PM
#12 (permalink )
thanks
06-25-2007, 09:04 PM
#13 (permalink )
There will be cutting/splicing involved but nothing anyone can't handle
06-26-2007, 07:19 AM
#14 (permalink )
were can i get the relay because i installed them last night and the hid's only work when the high beams are switched on. when i take high beams off regular lights work so i'm assuimng i really need this relay anybody know were i can buy one?
06-26-2007, 07:46 AM
#15 (permalink )
Member Number: 22294
Linear Mode
» Site Navigation
> Other Vehicles
» Network Links
