Old 10-01-2006, 09:09 PM   #1 (permalink)
USAFFirefighter's Avatar
Member Number: 39163
Default HELP!!!! W/marker light mod
ok so i was on here and i got the "instructions" on how to wire the marker lights to blink either with or alternate to the coresponding turning signal. well when wiring i confirmed my work did a dry test run then i blew a fuse didn't think anything of it cause i have planty for the car. well i dissconnected the wires and put it all back to it's original state. well when i went to check that my interior blinker started blinking fast to tell you, you got a bad bulb well i checked the bulb it was good but when i took my cucuit tester to the harness i got nothing so i checked both fuse boxes nothing was blown. the right front turn signal is inop but the left side works perfectly what the hell could it be?
USAFFirefighter is offline   Reply With Quote
Old 10-08-2006, 08:58 AM   #2 (permalink)
Default come on some one has to know
is there anyone that can help with this if anyone has the wire diagram that would be great or if they know how many f'n relay's are between the right turn signal to the switch that would be great too please i need help i checked all the fuses i checked the bulb and that part it sits in i traced all the wires and i still got nothing the right turn sigal only works as a marker light but not as a signalwhat ever it is it has to be somthing with just that front part cause the rear one works i am just getting so irratated with this.
Old 10-08-2006, 09:19 AM   #3 (permalink)
Member Number: 17930
Trader Rating: (58)
Did you use my instructions? When you say the front blinker doesnt work, does that mean that even the running light in the head light does not work? You need access to a DMM (digital Multi meter) and you need to test and find out how much (if any) power is getting to the front bulb. Sounds to me that when you did your dry run, you had a power wire grounded. Try swapping bulbs from left to right and put the wires completely back to stock. If you swap bulbs and it works then you do have a popped bulb.
2004 E.Blue Srt-4*SOLD*
2002 Acura Rsx Type-S *SOLD*
2003 Mini Cooper S *Current*
04pshhh is offline   Reply With Quote
Old 10-08-2006, 09:21 AM   #4 (permalink)
Trader Rating: (58)
Just re-read the second post you posted about the marker light. You need to test the turn signal wire going to the right. That right there will tell you if the problem is either with the bulb, or before the bulb. If you take the car down to CC or something, ask one of them to test those wire for you and you will know...
Old 10-09-2006, 06:24 AM   #5 (permalink)
fivetoez's Avatar
Member Number: 9691
I gotta ask this..............WHY in the HELL would you want your lic. plate lights to blink??
_____5TOEZ______ 1967 Cadillac Calais 429 2dr., 1967 Chevelle 4sp. Conv. ,1978 Dodge 318 "Factory Custom"van., 2004 Dodge Srt-4,Stage1.5(E-Blue) & a couple motorcycles.
Old 10-09-2006, 08:10 AM   #6 (permalink)
Trader Rating: (58)
Umm I have no idea where you got the license plate light outta this....he's talking about the front bumper running lights on teh side. You can make them blink with the blinkers or blink offset with the blinkers. I posted a vid a while back where I did it to my srt when I had her.
Old 10-09-2006, 04:30 PM   #7 (permalink)
Default Help w/ marker light mod
well i checked it agian for the fourht time, but still nothing i checked the wires and everything still nothing to the light itself. i can't figure it out and i don't know who cc is but how much will they cost me? and can they fix the mirror switch and the right side window switch? i hope they can?
Old 10-10-2006, 12:07 AM   #8 (permalink)
Trader Rating: (58)
CC is Circuit City. You really need to check and see if the blinker is reciving power. It sounds as if it is not. What is wrong with the switches?
Page generated in 0.15158 seconds with 13 queries
