Old 04-21-2008, 10:25 AM   #1 (permalink)
ohioSRT4SHO's Avatar
Member Number: 48084
Default help with projectors please!!!
ok i got a set of the black headlights with the LEDS and halo rings but one headlight is 10times brighter then the passenger side i dont understand someone please help must figure out asap have to have car ready for nopi next month... thank you
ohioSRT4SHO is offline   Reply With Quote
Old 04-21-2008, 10:30 AM   #2 (permalink)
BoostJunkies's Avatar
Member Number: 50062
Trader Rating: (26)
Are you talking about the ebay Halo projectors? Maybe a bad bulb, not aligned, and or needs a relay? It can be alot of things. Pictures will help alot though.
BoostJunkies is offline   Reply With Quote
Old 04-21-2008, 10:43 AM   #3 (permalink)
correct. i checked the ground but thats fine..,.,
Old 04-21-2008, 11:04 AM   #4 (permalink)
Milkit18's Avatar
Member Number: 46113
Trader Rating: (18)
i had the same problem, my blub on the driver side sat different ly in the projector so it focused more down than where i aimed it.. = gay
Thermal TB & SCT Base Tune (252hp & 305tq)
Milkit18 is offline   Reply With Quote
Old 04-21-2008, 04:02 PM   #5 (permalink)
i dont think it has anything to do wit position
Old 04-21-2008, 07:54 PM   #6 (permalink)
Milkit18's Avatar
Trader Rating: (18)
if the bulb is not focusing right , light will be dispensed unequally.
Old 04-21-2008, 07:54 PM   #7 (permalink)
Trader Rating: (26)
what the guy above me said.
Old 04-22-2008, 02:01 AM   #8 (permalink)
morgantj13's Avatar
Member Number: 47175
i had the same issue...the bulbs that come with the projectors are pretty lame, imo. Go buy some silverstars, or anything for that matter, they will be much better than what came with the projectors stock, imo.
Old 04-22-2008, 10:35 AM   #9 (permalink)
how do i replace or fix?
Old 04-22-2008, 12:54 PM   #10 (permalink)
mosho93's Avatar
Member Number: 40955
I happened to be watching some street tuner show on speed a few months ago and they interviewed a guy with a Yellow SRT-4 and his license plate was something like SRT4SHO, i'm guessing thats you?
I assure you we're open
mosho93 is offline   Reply With Quote
Old 04-24-2008, 05:32 PM   #11 (permalink)
yea i was on nopi thats my old headlights i had
Old 04-24-2008, 05:52 PM   #12 (permalink)
SRTTurbo's Avatar
Member Number: 5464
Bro i found that if you turn the light bulb around it will turn out brighter. I had mine in different and it shown a black spot where the beam was supposed to be. so i turned the bulb like 180 degrees and presto theres the beam of light!
Best time Street tires stock turbo setup 13.501@103.31
AGP 3147 Stage 3 T3/T04 turbo kit, MaxxFab DP, PTP CV, DC's strut bar,180 degree stat, magnacore wires, ngk V-power plugs, AGP 3" CAI, IP2 filter, AEM UEGO AFR Wideband, Mopar STS, Mopar Stg 1 Springs, Booger Bushings, ebay CC, Deyeme MM's, Turbo XS RFL, Mopar Borla Exaust, IP2 CF Hood, CF kanards, CF Foglight bezles.
SRTTurbo is offline   Reply With Quote
Old 04-24-2008, 09:26 PM   #13 (permalink)
Milkit18's Avatar
Trader Rating: (18)
Bro pm me if you want new bulbs. I have Nokya Arctic White pro halogen blubs . Never used. I dont need them
Old 04-25-2008, 04:35 PM   #14 (permalink)
how would you change these headlights are inclosed
Page generated in 0.17926 seconds with 11 queries
