Old 05-24-2008, 04:07 AM   #1 (permalink)
BDM
Member Number: 27931
Unhappy Help: Keep blowing fuses when installing LED blinkers
I keep trying to install my 25 LED 3157 lights in my front blinkers I got from super bright leds. Everytime I try to turn them on they blow a fuse. I've even tried flipping them around to see if it was a polarity issue which it wasn't. It happens no matter which way they are in there. I must have blown 15 fuses trying different combinations. I tested these lights in my friends cavalier reverse lights and they worked fine on the first try.
I don't care if they will blink fast, I just want them to work! What am I doing wrong. Aren't some of you guys using leds in your front turn signals? I am so fed up with taking out the headlamps and putting them back in.
3157-x25 LED bulb
25-LED 12VDC
BDM is offline   Reply With Quote
Old 05-24-2008, 07:14 PM   #2 (permalink)
Netou's Avatar
Member Number: 29372
Trader Rating: (60)
Bad ground?
Netou is offline   Reply With Quote
Page generated in 0.12541 seconds with 11 queries
