Old 03-07-2006, 02:29 PM   #1 (permalink)
9camaro5's Avatar
Member Number: 26439
Default help with installing headlight bulbs
does any one know a easy way to change both the headlights and the fog light bulbs? there has to be a easy way. i have a 05 srt4. thank you
9camaro5 is offline   Reply With Quote
Old 03-07-2006, 03:08 PM   #2 (permalink)
Lighting Modifications Moderator
haknslash's Avatar
Member Number: 21686
Read the manual if you have one. It tells you exactly how to remove and reinstall the headlights. Its about as easy as it gets.
3 bolts on top holding the bumper on. 2 bolts on top per each headlights. A tip for getting them out is to twist the headlight and pull out on the bumper that touches the inner most area of the headlights. Pops out everytime.
Old 03-07-2006, 08:34 PM   #3 (permalink)
jmduke3's Avatar
Member Number: 11611
Hak always thinking of retro retro retro....
I think he is looking for the bulbs themselves. The headlight bulbs are relatively simple to get to and replace. The right one little bit harder just due to AC lines. The manual does tell you how though.
The fogs are a little more tricky. The left one is cake, twist, pull, unplug. The right one though, prepare to break your wrist and tear up your forearm. The window washer bottle is directly behind the fog light and will take some patience but can be done.
jmduke3 is offline   Reply With Quote
Old 03-08-2006, 10:25 PM   #4 (permalink)
Member Number: 38945
There are 3 torx screws on the retaining rings on the headlights, loosen each by 1/4 turn to make life even easier. I did mine on my now, barely modded 04 today.
Silver2004SRT4 is offline   Reply With Quote
Page generated in 0.15596 seconds with 13 queries
