Old 10-07-2006, 10:49 PM   #1 (permalink)
Member Number: 46735
Default Headlights stopped working?
Hey...I'm a newbie to the SRT-4 world. I just picked my SRT-4 up two days ago, and was driving it back to AZ when the headlights and foglights stopped working. The only way the lights will work is if the highbeam is on. Is this a known issue? Any idea on where to start looking?
fatherc_chris is offline   Reply With Quote
Old 10-07-2006, 11:00 PM   #2 (permalink)
jaymzx's Avatar
Member Number: 278
Trader Rating: (12)
Check your headlamp fuse. The highbeams are on a seperate circuit, the low-beams and fogs are on the same circuit.
If you bought the car used, and have any sort of warranty, one thing I would check immediately is the connector to the headlamp switch in the steering column. There is a known issue about the harness overheating and charring the connector. See this thread for more info: Fire in the Dash!!!!!
The reason I say if you have a warranty, get it handled early-on. It can be an expensive fix.
James NWSRT-4
READ AND LEARN:
Page generated in 0.11838 seconds with 13 queries
