Quote: Originally Posted by
Remax Realtor
Put your car on a flat surface 25ft away from a wall and measure the distance from the ground to your bulb. Now aim your lights about 1"-2" lower than that on the wall. Also make sure your bulbs are seated correctly. Silverstars are a little brighter, but not enough to make you get flashed than stock bulbs.
Thanks ... they were definitely aimed to high, but I fixed them. Overall their definitely an improvement over stock. Being able to see much wider is a plus because we have lots of deer around here.
