Old 01-29-2006, 08:38 PM   #1 (permalink)
spence's Avatar
Member Number: 17639
Default head lights and fog lights no worky???
last night i when i was leaving my buddies house i went to turn on the head lights and they didnt turn on nor did the foglights....i popped the hood and checked the connectors to my hids and they still didnt work... could it be a relay or fuse? any help would be appreciated...thanks
spence
spence is offline   Reply With Quote
Old 01-29-2006, 08:57 PM   #2 (permalink)
Hi N Mity's Avatar
Member Number: 33036
Trader Rating: (39)
i would check fuses 1st, but I am thinking that maybe the Multi Function Switch might of took a dump on you
Old 01-29-2006, 09:36 PM   #3 (permalink)
Lighting Modifications Moderator
haknslash's Avatar
Member Number: 21686
X2 for the MFS going out on you since you said both your parking lgihts and headlights went out. Your not using a relay upgrade harness are you? Do some basical troubleshooting and hope for the best. That stock OE harness isn't cheap to replace.
Old 02-01-2006, 10:51 AM   #4 (permalink)
yeller03's Avatar
Member Number: 23348
Mine did the same thing. I could pull the switch to turn the High beams on but I had to hold it back to make them stay on. Turned out to be the switch and had to replace the whole assy.
Nikon D80
18-50mm F/2.8
Nikon Crew Member #18
yeller03 is offline   Reply With Quote
Old 02-01-2006, 01:44 PM   #5 (permalink)
spence's Avatar
how much was it
Old 02-01-2006, 01:45 PM   #6 (permalink)
spence's Avatar
i dont have brights so i cant try that...but the guage lights come on and the turn signals work....
Old 02-02-2006, 08:19 AM   #7 (permalink)
yeller03's Avatar
I believe it was about $30. I dont remember if my turn signals worked or not but the gauge lights did come on.
Old 02-02-2006, 12:02 PM   #8 (permalink)
spence's Avatar
wow i just callled the dealership and they want 80 bucks for one....shit...
Old 02-02-2006, 02:39 PM   #9 (permalink)
SRToc Member
srt4andawarthog's Avatar
Member Number: 31523
Trader Rating: (31)
I kinda have the same problem. My running lights, and side markers work, and then if I turn it up a notch, my headlights turn on. My fogs aren't working though. I looked inside the fuse box inside the cabin. Every thing is fine in there. But recently I reset the fuse inside the engine bay to get a check engine light to go away. Did I maybe blow a fuse in there?
srt4andawarthog is offline   Reply With Quote
Old 02-02-2006, 02:50 PM   #10 (permalink)
AlbanySRT's Avatar
Member Number: 1066
Multi Function switch...Had it go out on me 2 days ago. $150 at the dealer...You can buy it for agout $60 and do it yourself.
"Is your neon fast?"
AlbanySRT is offline   Reply With Quote
Old 02-03-2006, 02:05 AM   #11 (permalink)
spence's Avatar
yep i just ordered one from some mopar store...57 shipped i belive....
Old 02-03-2006, 06:48 PM   #12 (permalink)
spence's Avatar
can anyone tell me how to wire a toggle switch up to the headlights...i work night shift and really need the car....
Old 02-04-2006, 12:11 AM   #13 (permalink)
SRToc Member
Trader Rating: (31)
how hard is the install?
Page generated in 0.20425 seconds with 13 queries
