Quote: Originally Posted by
srtlvr
How do u get rid of water build up or condensation inside of your head light one of mine is bad......how does the moisture get in there anyways.....
Well at any point did you take the headlight apart? If you did or still aren't sure what could be the cause, just take the headlamp out, and search for wear and tears on the rubber part that connects both the lamp and the back plastic piece. If you want to remove the condensation, and if you don't want to take the whole headlamp apart, my best bet would be to take the have it sit somewhere to dry up. Later when dried seal it up if cracked. Or if alls fails, buy a replacement. Hope this helps, goodluck. PM me if you have any other questions.
