Old 07-10-2008, 05:09 AM   #1 (permalink)
Member Number: 12036
Trader Rating: (17)
Default having trouble with hid in headlights and fogs
i finally put hid in my fog lights yesterday but one side keeps on going out whenever i hook up the other side. it's as if i can't have them both on together. they are 35watt 6000 k. is there something i should put in? i'm assuming its drawing too much energy. any input? thanks
Mods: Got too many to actually remember
srtjay is offline   Reply With Quote
Old 07-10-2008, 09:35 AM   #2 (permalink)
Lighting Modifications Moderator
haknslash's Avatar
Member Number: 21686
I wonder if anyone can guess what the 1st question is I'm going to ask him?.....
Old 07-10-2008, 12:51 PM   #3 (permalink)
Trader Rating: (17)
how about an answer?
Old 07-10-2008, 02:42 PM   #4 (permalink)
haknslash's Avatar
Aw you're no fun.
The solution: Make your own relay harness.
You don't want to run your kit off the stock wiring/MFS. Search "Fire in dash" and you'll see what I mean. Search any of these related wiring threads in this lighting section and probably 80% of them are mentioned by me to tell people to use a relay and wired correctly. Typically most of these issues people experience is from not using a relay or not having it wired correctly (which includes using a relay).
I have explained as well as others on here how to make your own harness. you can also check out HiDPlanet.com :: Index and see the University section for a very detailed and professional way to make your own.
Old 07-11-2008, 11:41 PM   #5 (permalink)
muledoe's Avatar
Member Number: 57540
Quote: Originally Posted by haknslash View Post
Aw you're no fun.
i just ordered a set of 4300 fogs and 6000k head lights from vvmw.com They came with relays and i know everyone says use them. If the whole point of a relay to not burn the stock wiring harness?
also do u know the number for the fog lights? i know the headlights are 9007 but what are the fogs?
Stone White '05 SRT4
muledoe is offline   Reply With Quote
Old 07-12-2008, 06:48 AM   #6 (permalink)
SRTMIAMI's Avatar
Member Number: 54645
subscribed for part number of fogs
SRTMIAMI is offline   Reply With Quote
Old 07-12-2008, 09:56 AM   #7 (permalink)
$PK$'s Avatar
Member Number: 47676
I want HID fogs soo bad. The website you said, vvmw.com does not exist?? Can you give me a link maybe
401whp 419wtq on pump gas tuned by Jannetty Racing Enterprise
$PK$ is online now   Reply With Quote
Old 07-12-2008, 10:55 AM   #8 (permalink)
muledoe's Avatar
fogs number are 880
here are the fogs i just bought eBay Motors: Xenon HID Kit Conversion H1 H4 H7 9006 H3 880 881 H11 (item 180264373868 end time Jul-11-08 22:12:03 PDT)
Old 07-12-2008, 04:04 PM   #9 (permalink)
haknslash's Avatar
There is a sticky that has all the bulb part numbers.... light bulb part numbers thread
Yes you need a relay harness unless you like fixing shit later on. Also some of those relay harnesses that come with those kits do not wire up the relay correctly. Understand a relay and how it works. Make sure you have it wired correctly so its actually doing something.
Page generated in 0.26547 seconds with 11 queries
