Old 11-04-2009, 06:29 PM   #1 (permalink)
Zero_psi's Avatar
Member Number: 71591
Default H-vac led problem
so i ordered some leds aka the base and all and i got them today ad they dont fit will some one please let me kno what to use for my h vac leds and alll or will thease fit
Autolumination Instrument Panel Light Bulbs & Lamps)
its the Introducing the Tri-Power 3 LED Bulb
The Widest, 3x Brighter - Best #74 Leds Ever Made!
Designed especially for gauges, and applications requiring a large uniform field of bright light
Bulbs are 3/4" (20mm) x 3/8 (10mm)" diameter at widest point with T5mm base to fit standard #74 or #37 sockets.
stage 1 with some other goodies
Zero_psi is offline   Reply With Quote
Old 11-04-2009, 07:06 PM   #2 (permalink)
SRT of the Month
LilSparkPlug's Avatar
Member Number: 17636
Trader Rating: (70)
You're ordering the wrong bulbs, we don't have a standard based #74 in our cars we have a Neo-Wedge 74 which has a twist lock base. Scroll down and you'll see the Neo-wedges on here:
SRT-4 Dodge Neon Forum Light LED Bulbs
Old 11-04-2009, 07:24 PM   #3 (permalink)
Zero_psi's Avatar
this is why i love u thanks
Old 11-04-2009, 07:32 PM   #4 (permalink)
Zero_psi's Avatar
would thease work? aka what size if they do?
Product Listing - CAR
NEOx High Power LED Instrument bulb
NeoWedge series 1 High Power SMD LED Twist Lock Instrument Cluster and Gauge illumination bulb - 6 lumen
Available in 3mm - 4mm - 5mm sizes and five LED colors
Select Size and LED Color
$ 2.29
Old 11-04-2009, 07:43 PM   #5 (permalink)
SRT of the Month
Trader Rating: (70)
Yes, order the 4mm ones from SuperBrightLEDS the 5mm ones have a base that is too large and it will not twist lock in. The 3mm are too small.
Page generated in 0.15210 seconds with 13 queries
