Old 05-03-2009, 03:47 PM   #1 (permalink)
aww sheet's Avatar
Member Number: 20431
Trader Rating: (31)
Default g37 retro
starting a new set with a pair of 3" g37 projectors w/ zkw lens
i might cutout that plastic shield inside the top of the projector
junk lens test fit the flange will probably need to be mounted inside the bowl
compare to an E55 projector
i might figure out a way to use this shroud
more to come soon
View Modifications
Old 05-03-2009, 08:20 PM   #2 (permalink)
aww sheet's Avatar
Trader Rating: (31)
gonna have to get rid of 2 mounting points which sucks
Old 05-03-2009, 08:21 PM   #3 (permalink)
aww sheet's Avatar
Trader Rating: (31)
i made the bracket for the passenger side. it alitte rough, but this its test fit.
Old 05-04-2009, 02:27 AM   #4 (permalink)
-ND4SPD-'s Avatar
Member Number: 458
Trader Rating: (50)
Do you know who makes this projector? Definately a Japanese company like Koito or Standley.
Is it Ds2 or something like H11?
John Ruckman
Stage 3 with all the goodies
See My Ride
ND4SPD DESIGNS
Old 05-04-2009, 03:57 AM   #5 (permalink)
Novak94's Avatar
Member Number: 45523
always something new
Novak94 is online now   Reply With Quote
Old 05-04-2009, 05:16 PM   #6 (permalink)
aww sheet's Avatar
Trader Rating: (31)
they're standley i believe, d2s bulbs, but i got these with dr2's so i got find some others
Old 05-04-2009, 05:26 PM   #7 (permalink)
Motorboy1's Avatar
Member Number: 51889
Trader Rating: (10)
nice. subscribed
Motorboy1 is offline   Reply With Quote
Old 05-04-2009, 07:04 PM   #8 (permalink)
aww sheet's Avatar
Trader Rating: (31)
bump new pics
Old 05-07-2009, 08:03 PM   #9 (permalink)
aww sheet's Avatar
Trader Rating: (31)
bump.........i need some suggestions for the bracket
Old 05-08-2009, 11:00 AM   #10 (permalink)
Remax Realtor's Avatar
Member Number: 3827
Trader Rating: (53)
Is it strong enough without the connector at the bottom? If you cant go all the way around with one piece, I would suggest cutting another piece and use some jb weld to hold it together. You want them as strong as possible so the proectors isnt bouncing when you hit bumps. As long as its able to hold the projector and you can adjust them there shouldnt be any issue.
2003 srt-4 *totaled*
2001 neon r/t with srt swap *sold*
2009 dodge caliber srt-4
Old 05-08-2009, 12:31 PM   #11 (permalink)
aww sheet's Avatar
Trader Rating: (31)
oh yeah its strong enough. its 12g steel. the onlu thing i'm worried about is, if you look at the 2 side holes of the projector, they'll have to be cut away. so some support will be compromised.
Old 05-09-2009, 06:10 PM   #12 (permalink)
aww sheet's Avatar
Trader Rating: (31)
Default changed out the lens for color
fresnel lens
zkw lens
Old 05-09-2009, 07:20 PM   #13 (permalink)
aww sheet's Avatar
Trader Rating: (31)
Default test fit w/o reflector
Old 05-10-2009, 07:53 AM   #14 (permalink)
aww sheet's Avatar
Trader Rating: (31)
more
Old 05-10-2009, 09:36 AM   #15 (permalink)
wiggyx's Avatar
Member Number: 58107
Trader Rating: (53)
12 gauge steel No wonder you go through cut off wheels like George Burns went through cigars! I also use "horse shoe" brackets, but I use 22 gauge and I just bend the edge up all around at a 90° angle in order to give it extra rigidity. I should go snap a pic of an extra that I have laying around.
Looks good so far though
Page generated in 0.19769 seconds with 13 queries
