Old 03-22-2008, 09:03 PM   #1 (permalink)
04BlueSkittle's Avatar
Member Number: 52567
Trader Rating: (34)
Default foglights without the headlights on can it be done.
i was just thinking about this. is their an easier way instead of cutting wires and running an individual switch to it.
Quote: Originally Posted by Goldenshisno View Post
Wouldn't a little water be OK because when you heat up water it turns to steam the Hydrogen separates from the O2) and so all you would be adding is some extra air and hydrogen and last i checked that's pretty flammable.
Quote: Originally Posted by S10jimmi View Post
What? Steam is still H2O. It doesn't separate into H and O2, thats much more complex. It stays as H2O.
04BlueSkittle is offline   Reply With Quote
Old 03-22-2008, 09:10 PM   #2 (permalink)
cavie187's Avatar
Member Number: 48529
easier... not sure about that, but there are some guys on here that have customized their switch and mated it with a jeep part that works relatively well. Not even sure where to tell you to search to find the thread, but it's on here somewhere.
I would rather just run the switch myself, but luckily it doesn't bother me in the least.
Funniest video(s) EVER! Part 1 Part 2
cavie187 is offline   Reply With Quote
Old 03-22-2008, 09:21 PM   #3 (permalink)
killerSRT's Avatar
Member Number: 34265
Trader Rating: (80)
Check the sticky on the fog light mod. I did mine and it was simple. I crossed two wires. When i twist the light switch, fogs come on. When i pull it, headlights come on. No problems and it took like 5 mins.
Member #13 of the "Ramenite Noodler"
killerSRT is offline   Reply With Quote
Old 03-22-2008, 09:54 PM   #4 (permalink)
SRT of the Month
LilSparkPlug's Avatar
Member Number: 17636
Trader Rating: (70)
^ I did the same thing two and a half years ago, very simple to do.
Old 03-22-2008, 10:24 PM   #5 (permalink)
05moparsrt-4's Avatar
Member Number: 52352
same here......
05moparsrt-4 is offline   Reply With Quote
Old 04-01-2008, 09:52 PM   #6 (permalink)
TenSix's Avatar
Member Number: 30687
Trader Rating: (13)
Quote: Originally Posted by 05moparsrt-4 View Post
same here......
TenSix is offline   Reply With Quote
Old 04-01-2008, 10:09 PM   #7 (permalink)
theRTguy's Avatar
Member Number: 61370
Trader Rating: (15)
I just did the re-wire mod over the weekend, just need a couple butt connectors,crimpers,screwdriver.
Good mod, EASY
2004 SRT-4 (20K Miles)DC SPorts Exhaust,MOPAR C.A.I.,AGP WGA w MBC, MOPAR STS,B WOODY Solid MM Tranny Mount.,3" D.P., 3"O2 Housing, 225/45 AZENIS, EIBACH PRO-KIT,AGP CC, Fuel Pump Re-Wire,180 Degree T-Stat,Fan Re-Wire,APEXI NEO, UEGO, N2MB W.O.T. BOX w/2 Step,AEROFORCE Scan Guage,
SouthBend Stage4
theRTguy is offline   Reply With Quote
Old 04-04-2008, 04:18 AM   #8 (permalink)
bizzy's Avatar
Member Number: 13066
Trader Rating: (68)
I did this almost right after I got the car.......Whenever the wifey drives the car she ALWAYS forgets to turn the headlights on
CCA Big FMIC/Perrin fuel rail/TXS Dtec FC/TXS Tunerbox/AGP wires/Bwoody solid mounts/IPPCoilovers/welfare(pt)sways/RAGE billet lca bushings/19" centerline stormsFULLYBUILTRace ported intake manifold/Race spacer/RPM 62mmtb/custom -8 an fuel feed/custom -6 an return/1050cc injectors.....100% E85
GT3076r Blinged out
be afraid I am
bizzy is offline   Reply With Quote
Old 04-11-2008, 12:30 AM   #9 (permalink)
Member Number: 58474
Buy a canadian srt-4 then they are automatically on all the time.
twism10 is offline   Reply With Quote
Old 04-13-2008, 03:39 PM   #10 (permalink)
Member Number: 34994
I was looking at my fuse panel yesterday and noticed 2 empty spots for "DRL" relays. Wonder if slapping in the correct relays from a Canadian car would be all that would be needed.
Personally, I want my fogs to be on all the time, just coming on with the ignition. I never use my parking lights, so it's either all lights on or all off.
'04 Silver SRT-4, AEM SRI, Mopar cat-back, Goldlines, no money left
siege is offline   Reply With Quote
Old 04-17-2008, 12:01 PM   #11 (permalink)
alpine's Avatar
Member Number: 5844
I've had my fogs on their own switch for quite some time. I just never mounted the switch (which I need to do, 4 years later haha).
If I recall, it was extremely easy, though I'm not sure if the instructions I used are still on this forum.
alpine is offline   Reply With Quote
Old 04-24-2008, 04:19 AM   #12 (permalink)
Member Number: 45460
i read the sticky but dont really understand..what are the issues with doing the rewire..
luvinboost is offline   Reply With Quote
Old 04-24-2008, 04:22 AM   #13 (permalink)
DJOrtiz's Avatar
Member Number: 17860
Trader Rating: (26)
yawn... bringing it oooooollllld school
~DJ and JPG for JR. Mods 09~
loved by peteblksrt4
DJOrtiz is offline   Reply With Quote
Page generated in 0.18124 seconds with 13 queries
