Old 05-08-2004, 06:00 AM   #1 (permalink)
Member Number: 3060
Smile Foglights to Driving Lights???
Anybody thought of this? I guess it depends on how many amps the wiring for the stock fogs will provide. Some small projector driving lights could really brighten up the night.
srthamp is offline   Reply With Quote
Old 05-10-2004, 02:50 PM   #2 (permalink)
SilvaDragon's Avatar
Member Number: 3690
Default 10 Amps = 60 Watts
The stock fog lights are fused for 10 amps, which gives you a maximum of
60 Watts for each lamp.
-Herb DaSilva
2004 SRT-4 (blue)
SilvaDragon is offline   Reply With Quote
Old 05-10-2004, 02:54 PM   #3 (permalink)
SRToc Member
Dr. Chris's Avatar
Member Number: 554
I thought about this myself, but have no clue about amps, or watts, or gigawatts, or flux capacitors.
Dr. Chris is offline   Reply With Quote
Old 05-10-2004, 03:13 PM   #4 (permalink)
Member Number: 3690
Default Stay under the limit
Gigawatts from a headlight would take the paint off the car in
front of you in traffic. That might actually be cool, after some
jerk in an SUV cuts you off.
But my point is, if you don't want to change any wiring, you could
install 2 driving lights with a maximum rating of 60 Watts each
in place of the fog lights, and all should be fine.
Old 05-10-2004, 03:24 PM   #5 (permalink)
SRToc Member
jaymzx's Avatar
Member Number: 278
Trader Rating: (12)
The weak point in the chain is the multifunction switch in the steering column. I would suggest using relays to switch dedicated power from the battery if you decide to go above 50W/bulb. Smoking steering column=baaad.
James
READ AND LEARN:
Old 05-10-2004, 03:48 PM   #6 (permalink)
Project Blue
SRTforums Admin
HybridKid's Avatar
Member Number: 595
Running relays are pretty simple to do. Plus I have Andrew's steering column as a spare. Actually thinking of changing the stock 'fog' lights anyway.
HybridKid is offline   Reply With Quote
Old 05-11-2004, 09:24 AM   #7 (permalink)
Member Number: 10632
Here is a good sight that sells quality lights/relay kits
http://www.danielsternlighting.com/
DragonDon is offline   Reply With Quote
Old 05-12-2004, 11:36 PM   #8 (permalink)
Turbo305's Avatar
Member Number: 10160
nice. experementation time..
Peace in mind is worth its weight in GOLD
Turbo305 is offline   Reply With Quote
Old 05-12-2004, 11:46 PM   #9 (permalink)
Discussion/Performance Mod
NoisufnoC's Avatar
Member Number: 136
I dont care about switching my lights out, i just want to be able to run the fogs with just my parking lihts for dusky/dawn times...or light rain, kinda annoys me that i can only run them with the headlights on
omgz!! i haz mods!!
Old 05-13-2004, 01:04 AM   #10 (permalink)
SRToc Member
jaymzx's Avatar
Member Number: 278
Trader Rating: (12)
Do a search for 'fog light mod'. Someone has a good writup on it.
Old 05-13-2004, 10:19 AM   #11 (permalink)
SRTforums Photoshop Expert
suzq044's Avatar
Member Number: 1660
i've been thinking about this one for SOME time.. like since i designed my 'evil twin' srt.. but since i prolly won't have an srt for a while i'm gonna do it with my first gen- my only problem is street legality.. anyone know if its street legal to use ur fogs as headlights??
suzq044 is offline   Reply With Quote
Old 05-13-2004, 12:02 PM   #12 (permalink)
SRToc Member
jaymzx's Avatar
Member Number: 278
Trader Rating: (12)
It's only illegal to have your fogs on while the high beams are on...but I think that varies from state to state.
Using your foglights/driving lights without the use of the main headlamp beams, I don't know if that's legal or not. Considering the driving lights are not likely DOT spec, I'm sure someone could write you a ticket for something
Old 04-18-2005, 09:29 PM   #13 (permalink)
all_bran's Avatar
Member Number: 22506
Default Rebirth!
Hey guys,
Sorry for giving this thread a new life after a year, but it is exactly the question I am looking for an answer for.
Is there a driving light kit that exists for the SRT4 that will replace the stock fog lights? with mounting brackets & everything so it's jus tplug & play?
Here's where I am coming from: I bought blazertech driving lights for my grand prix. I aimed them a little higher for country driving. I Just did a HID swap so my city driving is fine, just wanted to see if I could get a +300ft solution.
Literally those blazertechs would shine over 300 ft in front of you! But no side-to-side light at all. Strictly straight ahead.
Sum up: I would use my HID's for city driving, and replace my fogs with long distance driving lights for back country driving (or pissing off the a-hole on-coming that has his high beams on) Does a kit exist for these driving light replacements?
Any thoughts?
all_bran is offline   Reply With Quote
Old 04-18-2005, 09:34 PM   #14 (permalink)
Project Blue
SRTforums Admin
HybridKid's Avatar
Member Number: 595
Smile
Try taking a look at Modern Performance site. They are a vendor on here. Then give us a review if you do decide to use them.
Old 04-18-2005, 10:26 PM   #15 (permalink)
Mike V.'s Avatar
Member Number: 9234
http://www.modernperformance.com/dcx...rt4_piaa.shtml
A simply awesome product.
Mike
BSME
1995 Plymouth ACR Coupe
1997 Dodge Neon Sport Coupe
Mike V. is offline   Reply With Quote
