Old 05-30-2005, 03:17 PM   #1 (permalink)
SRToc Member
Member Number: 28252
Default Fog Light Rewire (EASY)
I just rewired my foglights the easiest way possible. Pop the fuse cover off the side of the dash, take out the 2 screws that hold it in place, pull out the fuse box (wires are very long), cut the pink/green wire and purple/white wire (they are the ones at the bottom of the fuse box), now hook up the purple/white wire that comes from the fuse box to the pink/green wire that goes to the harness and the pink/green from fuse box to the purple/white from the harness. When you are done the foglights and headlights work backwards. When you go to turn the headlights on the fogs will turn on. And when you pull the foglight switch out to turn on the foglights your headlights will turn on. A simple 5 minute job. If you cut the wires a little farther down on the harness you will never be able to tell you messed with it once you tape it back up.
05 Stone White SRT4 (Sunroof & Kicker Live'n Loud)
jacj is offline   Reply With Quote
Old 05-30-2005, 03:52 PM   #2 (permalink)
LowNSlowNeon's Avatar
Member Number: 3397
Trader Rating: (18)
Hrm - pics? :P
Of the wiring...
Sounds easy.. but I dunno if I'd want them that way or not..
R.I.P Nightshade
LowNSlowNeon is offline   Reply With Quote
Old 05-30-2005, 04:35 PM   #3 (permalink)
E-BlueRocket's Avatar
Member Number: 11437
Trader Rating: (50)
all he did was reverse the wires that control each and the switch just operates backwards now, sounds good but i would probably get confused when i go to turn my lights on
No Boost... It Might Have A Button
E-BlueRocket is offline   Reply With Quote
Old 05-30-2005, 04:59 PM   #4 (permalink)
Blewbyu's Avatar
Member Number: 17234
ok just a question I may be wrong but is this going to cause your headlights to turn off when you switch to brights? or not? are the brights controlled seperately?
1997 GSX 12.21 @ 114 at 22 psi.... 1.59 60ft
2004 SRT-4 s2 12.89@109 SOLD 280whp and 330tq UNTUNED
PM ME IF YOU HAVE SAFCII or NEO PROBLEMS!!
NEO SETUP HELP 12.87 @ 109.2 on street tires (11.0 A/F)
Blewbyu is offline   Reply With Quote
Old 05-30-2005, 05:43 PM   #5 (permalink)
BoostedBlue's Avatar
Member Number: 13427
everything works fine, brights work too, cool mod, thanks for the info!
- 3" Aero Turbine Exhaust - CCA FMIC - Mopar STS - MSD Wires and NGK's - Progress springs - Prothane End Links - Prothane Motor Mounts -
BoostedBlue is offline   Reply With Quote
Old 05-30-2005, 11:07 PM   #6 (permalink)
SRToc Member
I dont know about the highbeams since I have HID's on my car. Its so simple to do and you can go back to stock in 5 minutes as well. I didnt want to rewire my lights and add a switch or have to spend $ to buy a PT headlight switch setup.
Old 05-31-2005, 01:33 AM   #7 (permalink)
projectNEON's Avatar
Member Number: 10290
Trader Rating: (33)
Nice. Never actually thought about that method but it's great to have more options for everyone to try out the one they like best. I might just have to try this. Please post pictures of wiring too lots of people do work best that way.
Best 1/8th: 8.205 @ 84.95 Best 1/8th MPH: 86.37
projectNEON is online now   Reply With Quote
Old 06-01-2005, 11:58 AM   #8 (permalink)
Zenkat's Avatar
Member Number: 10522
wow, that sounds fantastic. wish i'd thought of that. Although with that method, like another i've read, you will always have fogs on when you have your headlights on. No way to just put the headlights on by themselves...... but comon, who uses just headlights these days
Zenkat is offline   Reply With Quote
Old 06-01-2005, 02:20 PM   #9 (permalink)
Lighting Modifications Moderator
haknslash's Avatar
Member Number: 21686
I do.
The fogs take away from my projectors plus my fogs are useless now.
Old 06-01-2005, 02:24 PM   #10 (permalink)
SRToc Member
Bruins013's Avatar
Member Number: 3929
your my hero...def doing this!
2006 Pontiac GTO IBM auto-New
The original NE 04 E-Blue SRT-4-SOLD
277whp 304 wtq
Best time-12.88 @ 107
best trap of 110.52
Bruins013 is offline   Reply With Quote
Old 06-06-2005, 08:02 PM   #11 (permalink)
Member Number: 25039
high beams still work????
I don't use search so Ban me!!!!..........visit MAJESTICTURBO.COM
antihonda is offline   Reply With Quote
Old 06-06-2005, 08:11 PM   #12 (permalink)
go_BLUE_2's Avatar
Member Number: 6766
Trader Rating: (21)
good idea! I might have to give this one a try! Who all has done this and verified functionality?
What size fuses do each of the wires use? Are they on the same fuse?
Thanks!
06/17/05 12.659 @ 110.58 - 8.5/24.5-15 Slicks
05/22/05 307.54 HP / 381.20 TQ - Stock Turbo
go_BLUE_2 is offline   Reply With Quote
Old 06-07-2005, 11:18 PM   #13 (permalink)
cooper232's Avatar
Member Number: 12276
bump for the last post by go_BLUE_2.... i am about to walk outside right now and do this but want info about the fuses...
and no one ever answered... do the high beams still work?
need a bumper cover! anyone? anyone? bueler?
cooper232 is offline   Reply With Quote
Old 06-07-2005, 11:22 PM   #14 (permalink)
i have had it done for like a week now and works great and high beams work too
Old 06-07-2005, 11:25 PM   #15 (permalink)
cooper232's Avatar
you didnt change any fuses or anything? and at the moment i dont have any bulbs in my foglights so do you think this will have any effect on the headlight actually coming on?
