When the high beams come on, the fog lights go out. That's normal behavior.
I suspect that you simply have a burned out high-beam filament in the driver's bulb.
Swap with the bulb that you know works and see if you still have the issue on the driver's side. If it moves, replace both bulbs and forget about it.
Reason: I can't read...
