Old 08-22-2006, 08:55 PM   #1 (permalink)
Member Number: 40392
Default fog light mod
i just brought an o5 srt (used) and i think they done some kind of fog light mod .Anyone know where to look to undo the mod.. or explain how the mod works?
mike c is offline   Reply With Quote
Old 08-22-2006, 10:29 PM   #2 (permalink)
Member Number: 34952
is it where the fog lights stay on when the headlights are off? if so look at ur fuse box to the left of ur steerign wheel(pop of the little door thingy first) and u will see where he cut 2 wires, switched them around, and either soddered or put them back together....just undue what he did, cut the wires again and switch them back around to the way they were(they are color coordinated so u will know)
boostin2.4 is offline   Reply With Quote
Old 08-23-2006, 08:28 PM   #3 (permalink)
Default thanks
thanks for the info
Old 08-24-2006, 07:38 PM   #4 (permalink)
ddgsrt4turbo's Avatar
Member Number: 37230
whats the point of this "mod" in the first place!?!?!
CAR IS SOLD!!! I NO LONGER HAVE IT!!! IT IS CURRENTLY BEING TRASHED!!! (roasted tires, 38lb of boost on stock fuel + more) the guy is an idiot!!!
ddgsrt4turbo is offline   Reply With Quote
Old 08-24-2006, 08:05 PM   #5 (permalink)
jaymzx's Avatar
Member Number: 278
Trader Rating: (12)
Driving with the fogs on without the main beams. I plan to do it so I can use the foglights like 'daytime running lights'. It's also handy when you have HIDs and don't want to 'burn' them during the day or at dusk.
James NWSRT-4
READ AND LEARN:
Old 08-24-2006, 08:33 PM   #6 (permalink)
i have it done because i have aftermarket blue head lights, and in dusk and dawn that color of headlight is useless, also in the rain i do fogs only
Old 08-28-2006, 10:19 PM   #7 (permalink)
E-BlueRocket's Avatar
Member Number: 11437
Trader Rating: (50)
Ive got mine done the same way, and i did it for the fact that if its just dark enough to where you cant see your gauge cluster, but you can still see the road and dont need the headlights on you can just hit the fogs and it looks cool and you can also see the speedo, etc.
No Boost... It Might Have A Button
E-BlueRocket is offline   Reply With Quote
Page generated in 0.14101 seconds with 13 queries
