Old 06-05-2007, 11:11 AM   #1 (permalink)
Junior Moderator
Jmhm17's Avatar
Member Number: 24437
Default flashing side markers
i remember a while back seeing a thread about some one who make the side markers flash with the blinkers. i cannot find the thred and i searched high and low.. its not in the how to section and i coudlent find it here. dose anyone remember this thread or have it bookmarked? thanx
* Disclaimer...The above post may or may not have misspelled words ...deal with it...
**Sold**
Best E/T 12.699 @ 108.97
Best MPH 12.856 @ 110.32
Jmhm17 is offline   Reply With Quote
Old 06-05-2007, 12:01 PM   #2 (permalink)
Lighting Modifications Moderator
haknslash's Avatar
Member Number: 21686
You can wire them off the turn signal/parking light as a two wire hookup and it will work just like any other "side marker"
Old 06-05-2007, 01:17 PM   #3 (permalink)
Junior Moderator
Jmhm17's Avatar
so clip one of the wires? and splice it to the turn signal? is there a way to make is shut off when the normal turn signal flashes? so the corner light stays on but it flahses off when the turn signal turns on. can you ms paint me a scimatic of this
Old 06-05-2007, 01:56 PM   #4 (permalink)
haknslash's Avatar
The way it would work is that if the parking lights are off and you hit the turn signals, both the side marker and the front turn signal would blink at the same time. When the parking lights are on or the headlights and youy click the turn signal, the front signal and side marker would alternate flash sequence. That is how you traditionally wire in side markers as turn signals/side markers.
Get access to the side marker light wires. You will see two wires attached to the lamp. Cut the ground wire about a couple of inches from the lamp. Give yourself some room. In order for this to work, you MUST CUT the wire. Splicing into it will not work.
Next move onto the front turn signal/parking lamp connector. You will see three wires going to the single lamp in the plug. One is ground, another is the turn signal, and the other wire is the parking lamp. Carefully cut about 1/2 inch of insulation from the turn signal wire. DO NOT cut the wire, just the insulation from it, so about 1/2 inch of bare wire shows.
This is the wire that you are going to attach to the ground wire of the side marker light that you cut earlier. Connect the two wires together with quality barrel connectors and tape them up with quality 3M electrical automotive tape or use heat shrink (best). If you wish you can solder them as well, but it is not necessary and would give you the best connection.
I know this sounds strange to some people connecting a ground wire to the hot wire of the turn signal, but it works . The hot wire acts as a intermitent ground for the side marker and alternates in cycle.
Do the same for the other one...
The parking lights and side marker lights will work the same as normal. In the daytime, when you put the turn signal on, the side markers will blink with the turn signal. At night, when you have the parking lights on, and use your turn signal, the side marker lights will blink opposite of the turn signal. Meaning, when the front turn signal blinks on, the side maker will blink off, and visa versa.
This should work. I haven't done it on my car but this is the general way to wire them up and how I did in on my previous car. Works like a charm
Old 06-08-2007, 10:04 AM   #5 (permalink)
Junior Moderator
Jmhm17's Avatar
awsome thanx for the write up hak. ill give this a shot. one question though, insted of cutting the insulation on the hot wire can i just use a splice connector? also what color is the signal wire?
thanx again man!
Old 06-08-2007, 10:38 AM   #6 (permalink)
haknslash's Avatar
thanx again man!
Not sure what color the wire is. Use a test lihgt or multimeter
Yes you can use splice connectors instead of striping back the insulation and wiring it in. I just am not a fan of those as they can work them selves a weak or loose connection over time.
Old 06-08-2007, 10:53 AM   #7 (permalink)
srtowner's Avatar
Member Number: 4573
Trader Rating: (78)
just looking
FOR ALL YOUR PERFORMANCE NEEDS
srtowner is offline   Reply With Quote
Old 06-08-2007, 12:50 PM   #8 (permalink)
Junior Moderator
Jmhm17's Avatar
should we sticky this? ill post up a how to when i do it. i hope i dont short anything out.. the whole ground on a hot wire is kinda weird but eh.. ill try it.
how dose it flash during the day? dose the power for the marker light act as a ground while the ground connected to the signal acts as the power? that makes sence.. hmm ya this makes sence now.. its weird how simple it is to make it work that way.
Old 06-08-2007, 10:10 PM   #9 (permalink)
haknslash's Avatar
Yes I know its wierd but it works.
I'll sticky it once we get some pics. I might do it this weekend on Sunday if I have time and you haven't done it yet.
This also might be the last weekend I own this car
Old 06-08-2007, 10:14 PM   #10 (permalink)
viperwolf's Avatar
Member Number: 40449
Trader Rating: (31)
I like
Clarksville,Nashville,(TN) and Surrounding Areas
-viperwolf=(blue)-Blacksquirrel = Ken(Red)
-SILVERFLASH=Alan(silver)-ehr242=Roach(blue/s stripes)
-wesnightwolf=Wes(silver)-SnailPowered=Elighe(Red)
-lowor=Nick(silver)-Spools=David(black)
-SRT4EH - Eddie(yellow)-SRTrent =Trent(orange blast)
-turbineinstinct=mark james(red srt)
-20psi=Drew (orange)-Jukie=____(silver w/ mopar hood)
viperwolf is offline   Reply With Quote
Old 06-09-2007, 12:27 AM   #11 (permalink)
Member Number: 46928
I figured somebody knew how to do this...I did something similiar on a former car...thanks for the info Hak...
SRASRT4 is offline   Reply With Quote
Old 06-09-2007, 09:25 AM   #12 (permalink)
viperwolf's Avatar
Trader Rating: (31)
Thanks for taking the time to share all this HAK. that was really cool of you
Old 06-09-2007, 02:04 PM   #13 (permalink)
Junior Moderator
Jmhm17's Avatar
i thought you sold it months ago..
Old 06-09-2007, 06:58 PM   #14 (permalink)
haknslash's Avatar
Nah, couldn't sell it because I had headlight orders left to finish. Now that everyones is already done with the aiming for the most part, I can finally sell the car. Getting something MUCH slower but I need a SUV because I'm starting a family with a lil one and have a big ass dog now. Looked at a nice loaded up Highlander last night.
Hopefully I'll money left over from the difference in payment to buy me another sportbike to satisfy my go-fast needs from selling the SRT.
You guys are welcome for the info. That's what I'm here for
Old 06-09-2007, 11:07 PM   #15 (permalink)
Senior Moderator
Nick Fury's Avatar
Member Number: 19761
Good idea Jason, want to do it this wed? We can snap some pics while doing the wireing
Need Boost
Nick Fury is offline   Reply With Quote
