Old 11-04-2004, 07:21 PM   #1 (permalink)
SRToc Member
mysrt4ownsyou's Avatar
Member Number: 947
Trader Rating: (51)
Default FINALLY!!! FULL control of your foglights! l00k!...
okay....since day 1....a pet peeve about this damn car of mine has been that you HAVE to have the damned headlights on in order to have the foglights on, and not only that, but once u do...they shut off when switch on your highbeams. Besides that....i since always wanted to do the following 3 things:
1) be able to turn the foglights on WITHOUT the parking/cluster lights switched on
2) be about to turn the foglights on ONLY WITH the parking/cluster lights switched on
3) be able to KEEP the foglights on WHILE the highbeams are switched on
basically...have FULL independent control at your finger tip of the foglights whenever you wish in whatever of those senarios you wish. Well...i finally did it today! To make it short and simple...here's what's involved:
BEFORE WE BEGIN!: Get your parts/tools you need for the job:
a) switch, got from radio shack, part # 27-693 - $2.86
b) drill and drill bit (5/8 but use a smaller one to start the hole, and you will have to make it a bit wider in the end)
c) wire - 12/16 gauge
d) use a sauder gun w/sauder, heat shrink wrap, and black electrical tape
e) wire cutter/stripper
1) LET'S GO!
first, remove the kick panel under the steering column w/the 2 screws holding it in place. *note: be careful not to break the snap tabs that hold it in up top*
2). mount your switch on the little tab behind the stock headlight lever, use the drill bit as mentioned above to mount.
3) once mounted, now open up the side gray fuse panel inside the car on the driver's side of the dash. remove the two screws holding the fuse box in place so you can pull it out and get to the bundle of wires in the back of it.
4) locate the pink wire w/the green stripe on it
5) tap into the pink wire w/the green stripe and run it that extenstion you tapped into it with to one prong on your switch from radio shack
6) now, run another wire from the other prong on your switch to a 12v source in the car
7) that's it! have fun, clean up shop, and put the car back together and voila! FULL CONTROL of your fogs how dodge SHOULD have made it from the start!
*NOTE* i'd highly recommend for a pristine clean-cut job, to sauder all your connections up where you tapped into, slide some heat shrink wrapping over every one, use a lighter to apply heat to it to make it shrink down, then wrap around it w/black electrical tape
compliments and MAJOR thanks to Cali's how-to here, click to see through it and use the pics to help: (btw...for FULL control like i just wrote up, you use the EASIER method believe it or not, which is method #2 in the link below)
http://www.dodge-srt4.com/howto/Fog_Light_Mod.pdf
mysrt4ownsyou is offline   Reply With Quote
Old 11-04-2004, 07:37 PM   #2 (permalink)
acesrt04's Avatar
Member Number: 10575
Trader Rating: (18)
I didn't understand your instructions. Why don't you do it on my car so maybe I'll understand then.
Disclaimer: All DaimlerChrysler employees, dealerships, service personnel or employees family, friends, or acquaintances: This Post or any other post by the screen name ACESRT04 no way constitutes an admission of tampering, modification, usage, or alteration of my SRT-4 in such a fashion as to void, deny or otherwise refuse service on any service contracts or warrantees.
acesrt04 is offline   Reply With Quote
Old 11-04-2004, 08:52 PM   #3 (permalink)
srt4turbo04's Avatar
Member Number: 7676
I'd put this up for a sticky
AGP DBB 50 trim + all the good stuff. Basic street tune, needs some dyno time now.
Best Time: 7.92 @ 88 MPH (stock turbo and slicks)
Best Time with 50 Trim:
8.54 @ 91 MPH (2.2 60') (19 PSI) (Street Tires)
Plenty of room for improvement!
srt4turbo04 is offline   Reply With Quote
Old 11-04-2004, 08:57 PM   #4 (permalink)
Member Number: 14472
pics maybe?
Becca is offline   Reply With Quote
Old 11-04-2004, 09:11 PM   #5 (permalink)
Kevron's Avatar
Member Number: 2866
Fog lights go off when high beams come on because of federal regulations, or so I was told. But full controll of them is good for us public folk.
Chrome polished muffler bearings, oil gapped at 23, Hyfrenufren gauge, fuel injected brake lines, Fully synthetic blinker fluid, and a dream to keep me going.
Kevron is offline   Reply With Quote
Old 11-04-2004, 09:21 PM   #6 (permalink)
SRToc Member
Member Number: 947
Trader Rating: (51)
Quote: Originally Posted by Becca
pics maybe?
pics are all in the link at the bottom of the first post, thanks to Cali
Old 11-04-2004, 09:22 PM   #7 (permalink)
SRToc Member
Member Number: 947
Trader Rating: (51)
yes, can someone please sticky this?
Old 11-04-2004, 09:38 PM   #8 (permalink)
SRToc Member
srt4turbo2004's Avatar
Member Number: 3894
Yay a cheap mod that I like and can do over the winter storage. I may even attempt some power rear windows too. Thanks.
SRTOC #331, First SRT-4 Owner In Atlantic Canada
Mopar Bov,K@N Filter, Borla Cat Back, Stage 3w/toys, 3" 02 and downpipe, high flow cat
srt4turbo2004 is offline   Reply With Quote
Old 11-04-2004, 09:59 PM   #9 (permalink)
Exhaust Depot's Avatar
Member Number: 143
Trader Rating: (98)
Why you trying to be a NYer when your from PA. So please pronounce it like you PA do. Get your own accent punk! Pronounce it Solder not sauder. Only us NY can pronounce it sauder. ANd dont tell me you have a NY accent caws you dont punk!.
Exhaust Depot is offline   Reply With Quote
Old 11-04-2004, 10:14 PM   #10 (permalink)
spineshank385's Avatar
Member Number: 723
hector, arent you down in florida???
spineshank385 is offline   Reply With Quote
Old 11-04-2004, 10:25 PM   #11 (permalink)
SRToc Member
Member Number: 947
Trader Rating: (51)
lmao! oh well..i was typing this up w/my gf here and i typed "solder" and she said nooo noo no...its spelled "sauder" so i figured wtf and spelled it like that anyway lol oh well...should i edit the original post?
Old 11-04-2004, 10:31 PM   #12 (permalink)
Member Number: 143
Trader Rating: (98)
Yeah but im still a Bronx Bomber though im not there. Miss whitecastles, pizza, bagles etc.
Nah, no need changing your post Mr. Ownsyou, you got owned already.
Old 11-04-2004, 10:53 PM   #13 (permalink)
blacksheep's Avatar
Member Number: 14962
Trader Rating: (12)
back on topic -
Nice writeup and thanks for posting this information!
Some questions:
1) your instructions in pdf say locate wire as shown - could you change it to the color combo - looks green and pink? Easier to understand.
2) When you say cut away, do you mean cut it off totally? Your pics look like you just spliced them and the instructions up top say the same. Sorry, I am just a slow learner!
3) couldnt you connect it to a switched 12+ ignition so when the key is turned off, the fogs will go off and no way to accidentally kill the battery!
I think Hectors turbo timer instructions may mention one! Just curious
Thanks!
1995 Civic SI hatchback
2005 Suzuki SV650S
blacksheep is offline   Reply With Quote
Old 11-04-2004, 11:22 PM   #14 (permalink)
SRToc Member
Member Number: 947
Trader Rating: (51)
Quote: Originally Posted by blacksheep
back on topic -
Some questions:
Thanks!
hey man, you're welcome, but like i said, the PDF is not mine, it's what i used to do mine...CALI made the how-to. and anyhow, for your ?'s:
1) the color combo i stated in the oringal post, it is the pink wire w/the green stripe (go back and read)
2) the PDF says to get a wire tapper and do it that way, but i dont trust them for some reason, so on my own personal install, i cut the wire in half, stripped away both ends, and attached a new wire stemming off to go to the switch, then SOLDERED everything up, heat shrinkwrapped it and then electrical taped it up.
3) and yes...u CAN put it on a 12v switched power source, i didnt because i just didnt want to lol I like being able to turn stuff on when the key is totally off, thats just me. PLUS.....i figured this, #1...how could u forget to turn your foglights off? i mean....you'll see them on! lol and #2....even when you flip the switch, the little foglight emblem light illuminates on the dash that tells you they're on....so u cant miss it!
Old 11-05-2004, 06:04 PM   #15 (permalink)
SRToc Member
alpine's Avatar
Member Number: 5844
w3rd. So easy. Just finished and it's awesome. And yea, I hooked it up to my relay and there's no way I can leave them on w/o the ignition/accessory on (key in).
alpine is offline   Reply With Quote
