Old 10-01-2009, 08:37 AM   #1 (permalink)
srtwannabee's Avatar
Member Number: 5866
Trader Rating: (12)
Default elementmotor hid's radio interfearence
Ever since i hooked up my hid's i got from elementmotor I cant listen to the radio at night. As soon as I fire the hid's up my radio goes to complete static. has anyone else had this problem? Can i put some sort of filter on there?
Thanks~
1 of 1,067 Silver 05's
CSC member # 58
A.K.A DaluxSRT4
srtwannabee is offline   Reply With Quote
Old 10-01-2009, 09:29 PM   #2 (permalink)
aww sheet's Avatar
Member Number: 20431
Trader Rating: (31)
thats a bad ground somewhere
View Modifications
Old 10-02-2009, 08:20 AM   #3 (permalink)
Member Number: 5866
Trader Rating: (12)
bad ground on the hid's? or the radio?
Old 10-02-2009, 07:46 PM   #4 (permalink)
aww sheet's Avatar
Trader Rating: (31)
hids.........also if you can, do an amp draw on the ballast. it might be overloading also
Old 10-06-2009, 04:31 PM   #5 (permalink)
TypeRvtec's Avatar
Member Number: 51963
I have the same exact problem! My friend works at a performance shop and he's the one who got me the HID's. I went back to him with this issue, as I was telling him about it. 3 other people chimed in saying they have the same issue with theirs. The owner of the shop has the same issue as well in his Tahoe, and claims you will always get this problem with aftermarket high power HID's. I dunno, I just learned to live with it. There's gotta be some fix.
TypeRvtec is online now   Reply With Quote
Old 10-06-2009, 11:22 PM   #6 (permalink)
Member Number: 5866
Trader Rating: (12)
let me know if u figure something out, its annoying as hell, lol
Old 10-11-2009, 07:40 AM   #7 (permalink)
Crimsonghost's Avatar
Member Number: 72338
sounds like cheap/crappily shielded ballasts to me. Mine dont do that.
Crimsonghost is offline   Reply With Quote
Old 10-11-2009, 01:23 PM   #8 (permalink)
tinctorus's Avatar
Member Number: 30504
Trader Rating: (43)
Then the owner of that shop is a fucking moron because you DONT have to deal with it
I have 2 sets of hid's in my car one for the headlights and one for the fogs and I dont have ANY interference
you should check your installation and make sure you are using a relay for all of the wiring
Quote: Originally Posted by JPG View Post
yes, i am a huge giant black e thug and i will f**k up your world little boy, watch out.
tinctorus is offline   Reply With Quote
Old 10-11-2009, 03:37 PM   #9 (permalink)
TypeRvtec's Avatar
What do you mean a relay? I hooked them up as they are. They are plug and play?
Old 10-11-2009, 03:44 PM   #10 (permalink)
tinctorus's Avatar
Trader Rating: (43)
What does it sound like I mean
I mean are they wired up with a RELAY
as in are you using a relay for the power wire of the ballast
I dont care if its plug and play or not it should still have a relay on the power wire to isolate any feedback through the stock wiring and to take some load off of the flimsy ass factory wires
Old 10-11-2009, 08:08 PM   #11 (permalink)
Member Number: 5866
Trader Rating: (12)
it just has a fuse in the power wire. the power wire connects to the extra post in the fuse box.
Old 10-11-2009, 10:24 PM   #12 (permalink)
tinctorus's Avatar
Trader Rating: (43)
Yeah wire it up with a relay similar to the fog light mod from hak
Old 10-12-2009, 09:20 AM   #13 (permalink)
wow, most ballasts pull 6 amps @ power-up and 3 amps at full fire,. alot of load on the stock wiring without a relay. alot more then originally designed anyways..
Old 10-14-2009, 10:16 PM   #14 (permalink)
Member Number: 5866
Trader Rating: (12)
wish i could find other ppl with these hid's and see if they are having the same problem but elements posts have all been deleted
Old 10-14-2009, 11:28 PM   #15 (permalink)
tinctorus's Avatar
Trader Rating: (43)
Dude I have already told you what the problem is YOU NEED TO WIRE IN A RELAY IN ORDER TO STOP THE INTERFERENCE
You need to do that in order to fully isolate the HID wiring from the stock wiring in order to prevent electrical back feed and interference
you also NEED to wire in the relay in order to take the electrical load OFF OF your stock wiring or your gonna be posting a thread in a few weeks to the tune of
MY CAR CAUGHT FIRE AND ISURANCE COMPANY WONT COVER IT WHAT DO I DO?!?!?!?!?!?!?!
Page generated in 0.18823 seconds with 13 queries
