Quote: Originally Posted by Espo
WIll OEM MDX or Celica H7's work with aftermarket ballasts?
I need to find a set of bulbs for my ballasts, since mine were 9006.
Where is a good place to find bulbs?
I would highly recommend using OEM equipment. If your aftermakret ballasts have the HID standard P32D base then all you will need is D2S OEM bulbs and then use a H7/D2S adapter. That way if you ever decide to upgrade in projectors, you won't have to buy OEM bulbs over again and will just remove the H7 adapter ring.
If your aftermarket ballast has this red connector in the pic below, then your set...
