Old 02-15-2008, 03:46 AM   #1 (permalink)
Tripl3black_SRT-4's Avatar
Member Number: 58657
Default Don't like the "halos" in the eBay projector fog lamps? Here's your fix
first of all, i do have pics, but i will post them later today after work. i got the ebay projector fog lamps a few days ago, and last night i disassembled the units and separated the halo part from the projector part, then reassembled it. looks nice, yet subtle... and not so ricey like it does with that halo ring pics will be up late this evening... just thought id give you guys a preview
OBJECTS IN MIRROR APPEAR TO BE LOSING
Tripl3black_SRT-4 is offline   Reply With Quote
Old 02-15-2008, 08:22 AM   #2 (permalink)
VampOfVegas's Avatar
Member Number: 38215
Trader Rating: (76)
does it leave a groove in the fog light? Like something was there and now its not?
did you figure out what bulb it uses and how easy it is to replace w/ something else?
VampOfVegas is offline   Reply With Quote
Old 02-15-2008, 02:32 PM   #3 (permalink)
there are no grooves left, when i post up the pics later you'll see how the halo thingy "hooks" onto the "projector". im also going to take the bulb out shortly and see what type of bulb it is...
Old 02-15-2008, 03:09 PM   #4 (permalink)
ok so to be completely honest, i came upon this mod by mistake. last night i was taking a look at one of the lamps, when i noticed that one of them seemed to have a very minute chip in the glass of the lens, right where it sealed up against the black plastic housing. so i decided to take it apart and have a look
i loosened the two adjustment screws and took them out (one on each side of the housing). when i tried to pull the projector out, i noticed that the "halo" was clipped to the projector. i so loosed the clips (2 on each side of the projector) and then i pulled the projector out of the lamp housing. here is how the halo connects to the projector
upon removal of the projector from the halo, i noticed that the diameter of the halo was too big to come out of the back side of the housing. however, i needed to remove the halo in order i feel what that chip in the glass was. when i realized that it simply would not come out the back without scraping it against the sides of the housing, i decided to care less about the chip and put it back together.
this is where the accidental part starts... when i go to put the projector back in the housing, i notice that i simply cannot clip the halo back onto the projector while it is in the housing, because of very limited space... i had no room to put my fingers in there and grab it. i realized that now i had no choice but to yank the halo out of there... so i did
i ended up scratching up the silver paint on the halo pretty bad. i thought "great, now what?" i remembered people saying how they didnt like the look of the halo part; they thought it was ricey. so i got to thinking... "since the halo is already badly scratched, i wonder what it would look like with just the projector?" here are some more pics, of just the halo (the second one i removed, which for some reason basically came out with no scratches)
now, onto the bulb... in the rear of the projector, there are 2 small phillips head screws holding on a small plate. it looks like this
once you remove the plate, it looks like this
to remove the bulb, all you have to do is loosen another slightly bigger phillips head screw on the back of the bulb itself. it should look like this afterwards
Here are the bulb specs...
i took this information right off the back of the bulb. the brand is SUN LITE, and here were the associated numbers...
H3 12V 55W [E4] 2JJ
going by the text on the bulb, it is an H3 bulb. this particular one is rated at 12 Volts and 55 Watts. just to confirm that it is indeed an H3 bulb, here is a pic i found on google of an H3 bulb
so i guess i solved the bulb mystery, which makes me glad because these things would look nice lit up in yellow (my personal preference) or any other color.
here are some pics of the bulb directly out of the projector
now, the projector itself is 2 pieces... a lower body, and an upper cap. they are held together by the adjustment screws, and by some type of adhesive. the adhesive is really weak though, and the 2 halves of the projector separated almost immediately after i removed it from the housing. so i tried some permatex gasket maker, still didnt do the trick. they again separated right after i took the pics lol. so im going to superglue them together later (which is fine, because the bulb is removed from the back, and not the front). here are some pics of the projector
this is the inside of the cap
here is the inside of the projector body. it has a chrome finish to reflect light, just like any other bulb housing out there
here is the whole projector and lamp housing now assembled. i must say that these things look WAY better in person, the pics dont do it justice. the flash on the camera is too bright. when looking at these things, all you see it the projector cap, and the surrounding area is all black. anyway, here they are
i noticed after i took the pics that the projector was actually in there slightly crooked, because i forgot to thread in one of the adjustment screws lol. so if the projector looks cocked to the side in any of the pics, thats why. the only complaint i have about these housings is that the back of it is completely open. granted, its pretty dark back there anyway, since behind the fogs lamps is the engine bay. still, that open space could easily let dirt in, or perhaps moisture. so when i install these, im probably going to completely surround the back in some kind of black felt or whatnot, to "seal it off". it doesnt have to be a complete seal, i only want it to block dirt out. most headlight housings are slightly ventilated anyhow. let me know what you think!
Old 02-15-2008, 03:38 PM   #5 (permalink)
here's some more pics
in these following pics, i have the projector straight inside of the housing, not crooked like last time lol
as you can see, the harness for the factory fog lights will plug right into this, making for an easy install
Old 02-15-2008, 05:12 PM   #6 (permalink)
Trader Rating: (76)
Just ordered mine! I have an great idea! Might be the mod to do when you get this Fog.. i'll post my finding in this forum section. =)
Old 02-15-2008, 05:25 PM   #7 (permalink)
and what exactly is your great idea? haha jk. i think these would look SICK though with some real projectors if anyone has any other ideas, please post them up as well. i wanna put these in on sunday with my clear corners. im either going to get some yellow bulbs for the fogs, or go the other route... which would be matching these to my headlights, and buying the Silverstar H3 bulbs. ill also post up pics once these are on my car... my dirty, road-salt covered sorry excuse for a car
Old 02-15-2008, 05:28 PM   #8 (permalink)
SRT of the Month
bitts's Avatar
Member Number: 29842
Trader Rating: (98)
Can you post a pic on what they look like all put together on the car ?
thx.
bitts is online now   Reply With Quote
Old 02-15-2008, 06:02 PM   #9 (permalink)
thx.
im gunna install them on sunday, itll be a little warmer out then. btw, ive decided to just use the stock bulbs than came with it
Old 02-16-2008, 05:50 PM   #10 (permalink)
here are some pics of the projector fog lamps installed on the car. it was nice today so i put them on, along with my BC coilovers and my euro clear corners
i will also post night shots up later as well. its almost fully dark out right now, so ill go out there in a little bit and take some shots. i turned these on during the day, and they look nice. stay tuned...
Old 02-16-2008, 07:38 PM   #11 (permalink)
stxsrt's Avatar
Member Number: 37057
Trader Rating: (38)
Nice, I agree the main reason I haven't gotten theses fogs is mainly because the Halos looks so gay.
7.3 @ 101 1/8 mile
http://www.youtube.com/watch?v=RUBJUpApyeE
AEM EMS Tuned by Tampamike
E3 Turbo
Crane 14 cams
M&H Slicks 24s
stxsrt is offline   Reply With Quote
Old 02-16-2008, 07:45 PM   #12 (permalink)
the halo's are really easy to remove. i have night pics and a night video of these lamps, but my camera is not working now for some reason, it wont power up. the bulbs that come in this thing are only slightly less white than my sylvania silverstar headlight bulbs when looking directly at them. the cool thing about these fog lamps is that i have them aimed hitting the ground about 3 feet in front of the car, but they light up stuff all around the car, and way above it as well. i was shining these at my garage, and the light was very evident shining on the 2nd level of my house. looking directly at these tho, there isnt much glare either, which is good, my silverstar bulbs are ~4000K color. ill post up the vid when i get a chance to
Old 02-16-2008, 11:55 PM   #13 (permalink)
Adionik's Avatar
Member Number: 51197
Trader Rating: (25)
That doesn't look bad at all installed. I have mine wired to the side markers but I think i'll get these eventually. Did you ever get any at night?
or 16 whatev
WTB: LCA bushings
Adionik is online now   Reply With Quote
Old 02-17-2008, 12:29 AM   #14 (permalink)
beyondspexj's Avatar
Member Number: 30264
Trader Rating: (32)
looks good. too bad i cant run any fogs since i cut the supports outta the bumper.
if i ever get another bumper ill make sure to throw these in and wire up the fogs seperatly so the multi function switch wont fry...
04 NSRT-4 - DBB 50T Daily Driver
87 Mustang GT - New project..working on getting a big snail..
Old 02-17-2008, 08:06 AM   #15 (permalink)
yes i got some night pics, but my camera wont power up now i did get a video however, and ill load that one up from the other computer in my house when i get a chance
Page generated in 0.25606 seconds with 13 queries
