dome light problems
I had a burnt out dome light bulb for a while so I decided to get the LED dome light with the HVAC/gauge LEDS. Well when I put the LED in place it is already turned on. It doesn't matter if it's in the ON position or if the doors are open/closed, or even if the keys are in the ignition. I got a regular bulb just to make sure the LED wasn't the problem and the same thing occured. So basically there is a constant current running through it and no way of turning it off.
Any help?
Thanks, Dave
BRAVOPL POST ON HOW TO TEST FOR BOOST LEAKS:
"I'm sorry for an idiotic question. once i have this leak tester hooked up i start the car and then what? Do i just stand there and wait for some sort of whissle sound?"
SOLD
