Old 04-07-2009, 09:36 AM   #151 (permalink)
SPCorBUST's Avatar
Member Number: 4476
subscribed since my halos suck.
My 2010 resolution has been broken.
HID kit, fan switch mod, 180 t stat and coolant, booger bushings, mm inserts, alt heat shield, and hvac and dash LED's waiting to be installed.
Group buys kill me.
SPCorBUST is offline   Reply With Quote
Old 04-07-2009, 09:40 AM   #152 (permalink)
4TEHW's Avatar
Member Number: 5620
What sucks about them?
4TEHW is offline   Reply With Quote
Old 04-07-2009, 10:16 AM   #153 (permalink)
Member Number: 45202
Trader Rating: (17)
Quote: Originally Posted by silversport View Post
also from all the experts, I know these arent the best projectors out there but if its either stock headlights with HID'S or these with HID's whats better?
PnP HID Kit<Stock Headlights<DEPO Projector<Depo projector with hid kit<<Custom HID Retrofit
Thats my preference of the order they should be in. PnP in the stock headlights look nice, but the light is all over the place and you will probably get flashed all the time driving down the road.
STOCK
ghice007 is offline   Reply With Quote
Old 04-07-2009, 12:10 PM   #154 (permalink)
-ND4SPD-'s Avatar
Member Number: 458
Trader Rating: (53)
The stockers may look brigher but alot of that light is going places it shouldn't so that doesn't count. As far as usable lighting on the ground... I'd say both are about even in output.
One plus about the Projectors is you won't be blinding everyone with all the stray light. Other drivers will thank you for choosing the projectors.
As far as retroing. I'd say the stocker give you the ability to use just about every projector available to man but can be tricky to make them look nice, stock, OEM-like. The projector housings limit what projector you can use due to the size constraints but look great as all the cosmetic stuff is already done for you. It's really a matter of preference & confidence in your ability.
John Ruckman
Stage 3 with all the goodies
See My Ride
ND4SPD DESIGNS
Old 04-07-2009, 01:27 PM   #155 (permalink)
Member Number: 44988
Comone, bump to see some GOOD pictures of these in black with HIDS I know someones got them, even if just for the look during daytime such as the member whyconform. I just got my l.e.d tails so if they look good in black and work exceptionally well with hids it'll be a sweet add-on to my oreo theme
|Stage 1| |AGP WGA| |Borla Exhaust| |Hallman Pro RX MBC| |JMB 3" SRI| |E.D Hard Pipes| |JMB Radiator Hard Pipe Candy Red | |Bwoody Motor Mounts Candy Red| |HKS SSQV| |6000k HID| |n2mb Wot Box|
SRT4Passion is offline   Reply With Quote
Old 04-07-2009, 02:20 PM   #156 (permalink)
Super Moderator
SRT of the Month
LilSparkPlug's Avatar
Member Number: 17636
Trader Rating: (73)
These will never work exceptionally well, they have cheap projectors. They may look good in black, but as far as working exceptionally well....not going to happen.
Old 04-07-2009, 06:40 PM   #157 (permalink)
Member Number: 63834
so does anyone know about the eyelids? even if they do work without modding, i wonder how it would look with the turns being partially blocked at the top?
silversport is online now   Reply With Quote
Old 04-07-2009, 07:09 PM   #158 (permalink)
Super Moderator
SRT of the Month
Trader Rating: (73)
Just the same as it looks with the MPX projectors. The turn signal location and design are the same. There's a thread on here somewhere with people asking that same exact question.
Here you go: projectors w/eyelids
Old 04-08-2009, 12:50 PM   #159 (permalink)
cool thanks. I probably should have tried looking that up. i thought they removed the bump or something on these so it would make eyelid fitting weird? maybe im wrong
Old 04-10-2009, 06:51 AM   #160 (permalink)
Super Moderator
SRT of the Month
Trader Rating: (73)
The bubble wouldn't interfere with the eyelid that I know of.
Old 04-10-2009, 10:51 AM   #161 (permalink)
05rEdAcR.'s Avatar
Member Number: 63999
getting myself a pair of these depos and gettin rid of my halo's which i never installed but i like the depo look beter
05rEdAcR. is offline   Reply With Quote
Old 04-12-2009, 07:29 PM   #162 (permalink)
Doppleganger's Avatar
Member Number: 69247
Yea, I'm probly gonna snag a set of the Depos. Even though they're not real good projectors, I still prefer H7 over H1-based headlights. I'll start planning my retofit route. I'd like to do some compact bi-xenons in there, might have to do singles depending on room. The e46 singles in my WJ look alright, though not the ubersexy cutoff that some of the 3" projectors have.
Doppleganger is offline   Reply With Quote
Old 04-16-2009, 07:21 PM   #163 (permalink)
orngboost53's Avatar
Member Number: 48332
Trader Rating: (18)
would audi a4 projectors fit in here and what bulb do those projectors use for hid? i know you mighthave to modify the mounting of it but is the projector size the same?
trent
orngboost53 is offline   Reply With Quote
Old 04-30-2009, 09:26 PM   #164 (permalink)
Member Number: 34376
Why can't a company put a decent projector in there? Even if they were $500 for a set people would still snag them. Cheaper then a GOOD retro.
kornsined is offline   Reply With Quote
Old 05-26-2009, 09:57 AM   #165 (permalink)
04Srt-4Dodge's Avatar
Member Number: 21545
Trader Rating: (18)
Just to clarify, these depo headlights will mate with an aftermarket HID kit, correct?
JMB Ultimate Intake
Mopar Stage 1
Perrin Short Throw Shifter
Thermal Research and Design TBE
JMB UPP with HKS Sequential Blow Off Valve
http://aritria.myminicity.com/
04Srt-4Dodge is offline   Reply With Quote
