Old 10-26-2005, 10:56 PM   #1 (permalink)
SR20SRT-4's Avatar
Member Number: 11215
Trader Rating: (19)
Default Clear up a retro question...
I have heard from both sides, 1. you need to get the depo lights cause the factory glue is too strong, 2. you can take apart the factory lights just fine. Which one is it? Thanks
SR20SRT-4 is offline   Reply With Quote
Old 10-27-2005, 07:19 AM   #2 (permalink)
Lighting Modifications Moderator
haknslash's Avatar
Member Number: 21686
Stock lights won't come apart withouth cutting. Have fun . Many recent Dodge headlights have been this way for a few years. The stock headlights are made by valeo and the sealant they use is basically a one time use thing. It does not get loose with heat. You would more than likely melt portions of your housing before the lens would let up.
DEPO's come apart via heat at 250 degrees preheat for 8 minutes.
Old 10-27-2005, 07:46 AM   #3 (permalink)
Ude Lose's Avatar
Member Number: 4562
Trader Rating: (23)
I got them open without melting the headlight by using a heat lamp. It took about 3 hours but it can be done. Now the only thing i have to deal with is condensation. Sucks.
03 w/LSD, Stage1,AGP WGA,Spearco fmic,2.0 cams,Fidanza Gears,FBM-all ported,Mopar Exhaust,Mopar CF Valve cover,Mopar intake,TEIN Coilovers,Energy suspension full bushing kit,ACT street/strip clutch, Mp Short Shifter,Booger bushings, Rotora BBK,RAGE DP & integrated 3" 02 housing,Txs MBC,,DC Sports SB,Oil Gauges,Walbro fuel pump,JMB hard pipes/Greddy type S,Triple gauge pod,VIS CF Hood,CBD CF Trunk,18's.*Your all noobies unless you drive an 03*
Ude Lose is offline   Reply With Quote
Old 10-27-2005, 11:34 AM   #4 (permalink)
L0c0's Avatar
Member Number: 19414
Trader Rating: (29)
I had an 01 stratus r/t and baked the headlights for 5min at 250degrees and they came apart just fine. I've also heard the srt4's cannot be pulled apart with this method but still want to try. Let me know how it works out Jarrod...
L0c0 is offline   Reply With Quote
Old 10-27-2005, 03:26 PM   #5 (permalink)
killervenom's Avatar
Member Number: 14572
Hey guys once you melt your lights u'll need a set of these Sale for people doing retros! only 155 shipped even to alaska rather be safe then sorry.
Current Mods : Psi-Fi CAI, MSD 8.5 MM Wires, Mpx Heat Shield, DC Front & Rear Strut Bars, Mopar STS, Booger Bushings, JLM Motor Mount's, AGP Race FMIC, JBM Hard Pipes, Billet Check Valve, TL retrofit projectors, Mpx UDP, SRT Oil Press., Pyrometer, LFS Fuel Rail, AEM UEGO
***ALL FOR SALE*** PM ME OR EMAIL
killervenom is offline   Reply With Quote
Page generated in 0.18652 seconds with 13 queries
