Old 05-28-2005, 05:30 PM   #1 (permalink)
SyberKhanX's Avatar
Member Number: 541
Default clear corners/ rear licence plate light Q's...
Ok, First - the clear corners issue. I replaced the old yellow stock side marker lights with clear corners a while back, and swapped out the amber bulbs with super white bulbs from autozone or something.
Problem: Apparently the bulbs have gotten so hot the have melted the bulb socket housing to the bulb, compromising the vacuum of the bulb, and now I have no lights (side lights). I went to the dealership, and they told me there isn't a part for just that socket wiring, that I would have to replace the entire engine harness ($250). Where can I go to find just the bulb socket wiring so I can just splice the new wiring onto the old stuff, and not have to replace the entire assembly? I don't have any idea where to find a junkyard or something that I can search though that's not 100+ miles away from Los Angeles...
Also - Part 2:
Does anyone know what kind of bulb is over the licence plate, or how to get to it? I'd like to replace it with a red bulb, for cosmetic puposes.... :P
SyberKhanX is offline   Reply With Quote
Old 05-28-2005, 06:19 PM   #2 (permalink)
SyberKhanX's Avatar
Member Number: 541
anyone?
*bump*
Old 05-28-2005, 07:55 PM   #3 (permalink)
Rich Tideswell's Avatar
Member Number: 23966
the bulb should be a 194 for the side marker, 194a if you want an amber one. Autozone or pep boys should carry a pig tail socket assem. to fit these bulbs (2 wire, 1 postive and 1 ground) and i think i have one off my 92 daytona that will fit, giveme your e-mail and i can send you a pic.
sorry its so long.
Rich Tideswell is offline   Reply With Quote
Old 05-28-2005, 10:37 PM   #4 (permalink)
SyberKhanX's Avatar
Member Number: 541
Interesting.... I'll look into it. Send me the pic though, if you could. SyberKhanX@aol.com
Anybody have any ideas on the license plate bulb??
Old 05-29-2005, 10:17 AM   #5 (permalink)
demented_iggy_koopa's Avatar
Member Number: 13475
go to autolumination.com theyve got a link to a bulb guide for our cars it should be on there...im pretty sure thats illegal tho just a heads up...but im not positive on it
demented_iggy_koopa is offline   Reply With Quote
Old 05-29-2005, 03:36 PM   #6 (permalink)
SyberKhanX's Avatar
Member Number: 541
i'm aware of the legalities... wouldn't be the first thing that wasn't legal...
i.e. - clear corners with white bulbs, no front license plate, tint on my front windows in CA, BOV, etc...
well - off to Autozone!
Old 05-29-2005, 04:23 PM   #7 (permalink)
sent you an e-mail. let me know.
oh yeah, the harness was off my 88 daytona, not my 92
Old 05-29-2005, 07:13 PM   #8 (permalink)
srtowner's Avatar
Member Number: 4573
Trader Rating: (78)
For the bulb on the plate you have to remove the plastic part in your trunk where the trunk lock is. It is held on by the same type of clips that hold on all the other trim parts in the car. On my car I had to grasp the part from the bottom and pull out and up.
FOR ALL YOUR PERFORMANCE NEEDS
srtowner is offline   Reply With Quote
Old 05-29-2005, 07:16 PM   #9 (permalink)
DaZone's Avatar
Member Number: 1799
Also - Part 2:
I replaced mines with a red bulb- 194 bulb. At your local ricerzone. APC bulb.
Mods: S3w/toybox,CTI turboback,Iceman TB,AGP CAI,CCA Fmic, Mopar wires w/NGK Plugs. Turbonetics w/greddy type s bov. also: B&G Lowering Springs, Front&Rear Strut tower bar, Rex motor mount inserts, Progress Rear sway bar. AGP S3 Wg.
18" Exel Chromes w/toyo proxes 4
17" Nexo PX-5 w/ toyo proxes 4
Dynoed with HOM : 358hp and 359tq
DaZone is offline   Reply With Quote
Old 05-29-2005, 07:25 PM   #10 (permalink)
DaZone's Avatar
Member Number: 1799
heres a pic of mines. I got tooo much time on my hands. hhahahha!
one bulb is my stock bulb inside the package.
Old 05-30-2005, 02:55 PM   #11 (permalink)
SyberKhanX's Avatar
Member Number: 541
shweet! thanks for the info guys.
As for the Harness, Rich- thanks, but I'm gonna look for some old neons so I can just splice it, and the socket will still twist on to the corners, as I'm buying new ones anyway. thanks though!
Old 06-04-2005, 07:15 AM   #12 (permalink)
JCturboT's Avatar
Member Number: 6714
http://motormitedormancatalog.com/it...0CC7P1JA0HL7I0
This should do the trick....
Most Autoparts stores sell the Dorman/Motormite line of products.
Jeff
JCturboT is offline   Reply With Quote
Old 06-07-2005, 07:27 PM   #13 (permalink)
JCturboT's Avatar
Member Number: 6714
After looking at the stock pigtail this one is even closer to the one used in SRTs
http://motormitedormancatalog.com/it...0CC7P1JD17SATD
Jeff
Old 06-11-2006, 12:42 PM   #14 (permalink)
Jim
Member Number: 2643
That won't work, at least on 2004. You need to unbolt the light bulb housing from under the the bumper in the license plate area. Two screws and it's out. Once it's out, r&r the bulb and put the assembly back.
White 1990 Mustang LX 5.0
Silverstone 2003 S2000
No replacement for displacement...because I've got boost and displacement
Jim is offline   Reply With Quote
Old 06-23-2006, 06:42 PM   #15 (permalink)
Member Number: 9598
Clear corners with white bulbs IS legal in CA. Its the lack of an amber reflector surface thats illegal.
White and amber are the legal colors for parking and side marker lights.
Mopar00Neon is offline   Reply With Quote
