Old 12-23-2004, 03:13 PM   #1 (permalink)
DJOrtiz's Avatar
Member Number: 17860
Trader Rating: (26)
Default check engine light- light mod?
all right i have a stage 1 if this matters but......... today i did the blue gauges mod where you change out the bulbs with LEDs and when i put back the car back together and turned it on the check engine light turned on,
so a fellow rsx driver told me to disconnect my battery to reset it... well i did BUT will this effect my stage 1? and will it take care of my check engine light problem?
thanks danny
~DJ and JPG for JR. Mods 09~
loved by peteblksrt4
DJOrtiz is offline   Reply With Quote
Old 12-23-2004, 04:24 PM   #2 (permalink)
Member Number: 5294
Trader Rating: (13)
It won't affect your s1 just reset the computer and you'll see higher boost levels for the first few hard runs and then it will adjust by itself. Your check engine light shouldnt be on. If your reset it then it will go away. What mods do u have?
New dyno Agp 3147 Turbo/CCA Intercooler 16.43psi 320hp, 328tq (Untuned running off s2) Now At 20psi(est. whp is 385whp untuned)
CAR PICS!!
http://www.midwest-racing.net/04__Slvr_SRT4.html
http://www.cardomain.com/memberpage/580052/1
bigmosrt is offline   Reply With Quote
Old 12-23-2004, 04:45 PM   #3 (permalink)
glhs837's Avatar
Member Number: 215
Was the battery connected while you had it apart? If so, most likely you set a "bus" code. The three computers like to chat to pass the time. If one drops offline, say, the cluster computer (module) they take note of it. Pull codes, if it's a bus error that doesn't return, your cool. If it does come back, you'll have to check the cluster connections.
Old 12-23-2004, 05:37 PM   #4 (permalink)
qwiksilvertrav's Avatar
Member Number: 360
Yep, first things first run the codes and see what they are.
DCR Ported and Ramp modded Stage 3 w/ TT's
Form & Function EM Port + Cer Coat
AGP DFFMIC
AGP S3 wga
DCR Ported Intake manifold
DCR TB
B&B's TB 3' Exhaust no cat
Maxxfabb S3 O2 housing Cer coat
AGP CAI
ED hardpipes
Greddy Type RS BOV
Perrin STS w/ BB's
Prothane MM inserts
And some other goodies
qwiksilvertrav is offline   Reply With Quote
Old 12-23-2004, 05:48 PM   #5 (permalink)
Bacardi 151's Avatar
Member Number: 14061
Trader Rating: (34)
The title was a lot more interesting than the actually thread...
Former 295hp/344tq owner
Bacardi 151 is offline   Reply With Quote
Old 12-23-2004, 06:05 PM   #6 (permalink)
DJOrtiz's Avatar
Trader Rating: (26)
lol sorry for a disappionting thread bro.... but i reset the computer before my dumbass(thats french) pulled up the code. everything is back to normal and yes i had the battery connected when i removed the gauge cluster... i think thats what it was
but thanks guys
Page generated in 0.14527 seconds with 13 queries
