Old 05-02-2007, 06:07 PM   #1 (permalink)
YeahItsAHemi345's Avatar
Member Number: 36291
Trader Rating: (75)
Default Brights, reverse lights and rear defroster...no worky!
A couple hundred miles ago my brights, reverse lights and rear defroster stopped working. I'm just wondering if anybody else has had this happen.
YeahItsAHemi345 is offline   Reply With Quote
Old 05-02-2007, 06:07 PM   #2 (permalink)
Member Number: 37525
Trader Rating: (12)
check fuses? and bulbs?
dgillie is offline   Reply With Quote
Old 05-02-2007, 06:09 PM   #3 (permalink)
Trader Rating: (75)
Yezzer! No interior fuses, it's not the bulbs. I saw this thread...
Reverse lights went out.. ?
But I haven't messed with my tranny ever.
Old 05-07-2007, 09:20 PM   #4 (permalink)
Member Number: 39211
Check your grounds, G301 ties in your back up lamps and your rear defrost, the front high beams are on a separate ground. Ground 301 is in the trunk, left side just behind the left tail light on the left fender. Let me know if that helps.
NeoViper23 is offline   Reply With Quote
Old 05-09-2007, 03:36 PM   #5 (permalink)
Rymanrph's Avatar
Member Number: 31633
You have no idea how happy I am to hear this information. I've been without my defroster and reverse lights all year. Everyone said it was the LEDs that came off of the illumination wire on my defroster (I put red LEDs in all my window and door lock switches), but the illumination still worked so I didn't think it was true. I have a trunk light switch so that I can turn the the trunk light off if I need too. The light on the illuminated switch stopped working a while back. Turns out that's where its grounded. I bet you just solved my problem and saved me hours, possibly DAYS. I really hope this is the solution and if it is THANK YOU!
Stage 1, BWoody H-Brace & Traction Bars, BWoody Catch Can, ACR Rear Sway Bar, Mopar Catback, Ebay Intake, BC Coilovers, Mopar STS, 18x8 Tork Champions, Fiber Images CF Hood, MPX Intercooler, Slow Boy Racing Crash bar, LED/Halo Headlights, JMB Hard Pipes, HKS SSQ BOV, Ported Intake Manifold, LFS 60mm Throttle Body. My car is slower than yours
http://www.srtforums.com/forums/f41/...thread-448014/
Rymanrph is offline   Reply With Quote
Old 05-09-2007, 10:13 PM   #6 (permalink)
Glad i can help, working for Chrysler helps out every once in a while let me know if i can find anything else.
Old 05-09-2007, 10:20 PM   #7 (permalink)
Rymanrph's Avatar
I would have checkrd on it tonight but it rained, so I'll try tomorrow.
Old 05-10-2007, 09:13 AM   #8 (permalink)
Trader Rating: (75)
I'll check the ground later today, thanks for the help.
Old 05-11-2007, 12:36 AM   #9 (permalink)
Yeah let me know if you need me to look up the wiring for your brights too if you havent fixed those yet.
Old 05-11-2007, 08:27 AM   #10 (permalink)
Rymanrph's Avatar
Well I removed my secondary ground and popped a new fuse it there. It worked, but I won't know until I drive it around for a while if its permanent. Every time I put a new fuse in, it was last for a little bit before it finally blew. I didn't drive it today cause it doesn't have any gas, so hopefully I'll know sometime this weekend.
Page generated in 0.20460 seconds with 13 queries
