What is the brightest Reverse light bulb I can put in my 03? I am going to swap out the taillights for some new ones and I want the brightest lights for the reverse I can get.
thanks
If, all else fails just remember "Tuna and Cheese" and all will be good.
The LED units deliver a very nice beam pattern for reverse. Even painted . They are far better than stock tail lights ever were with a same wattage bulb. I don't care for colored bulbs so I'd personally say stick with stock since you got the new LEDs. They should be sufficient enough for you, if not get some night glasses j/k
If you like that one I will put the new pic on there the system has been changed since then and we are new redoing that one with MAs HK15X2 and two Visonik V918 X-Class amps.
