One day my brake lights and blinkers quit working and now i am stuck. i changed the two 15amp fuses and it worked for a day or so then they blew again. changed them and they work for 5min or so then POP. my left blinker works fine but as soon as i hit my right it blows. my brake lights blow the fuse too. any sugg woud be great, thanks
Did you check your multifunction switch in the encasement around the steering column? It could be burnt up. Have you always used factory bulbs or did you have some type of aftermarket bulb in there at any time (headlights, turn signals, etc)?
the switch seemed ok. the bulbs are stock. all the parking lights and headlights+ fogs work fine. suppose i could take the switch off and hit the brakes to see if fuse blows??
