06-17-2009, 12:13 PM
#1 (permalink )
Member Number: 7874
Brake Lights Fuse Keep Burning
The brake lights fuse keep burning up on me. I changed it 6 times now and each time it burns up when I start the car up or use the brake.
Any ideas to why that's happening, and how to fix it?
06-17-2009, 12:21 PM
#2 (permalink )
SRTforums Junior Admin
Member Number: 37340
Why it's happening? You have a short somewhere is my guess.
How to fix it? I would look around for a wire that doesn't look right. Possibly one that is stripped or something.
Unnecessary (4:51:23 PM): just got a new webcam
Unnecessary (4:51:29 PM): wanna cyber later...
06-17-2009, 12:29 PM
#3 (permalink )
Member Number: 13897
If it happens right away it should be an easy short to find.
I would disconnect one component at a time until it quits blowing. That will get you started.
06-17-2009, 12:31 PM
#4 (permalink )
Member Number: 7874
What wires I should be looking at?
06-17-2009, 12:32 PM
#5 (permalink )
Check your brake lights first. (If one doesn't work, then we obviously have a place to start)
Check the sockets to see if any of the bulbs are melting into the socket, etc.
Disconnect one brake lamp at a time.
STart there.
06-17-2009, 12:36 PM
#6 (permalink )
Member Number: 7874
Quote: Originally Posted by
thepowertowin
STart there.
Already did that. Also, changed the bulbs just in case. The problem is that they would work sometimes for a while and then at one point the fuse is burnt, not sure when or why.
06-17-2009, 12:38 PM
#7 (permalink )
what is the fuse# that is popping?
06-17-2009, 12:43 PM
#8 (permalink )
Member Number: 7874
15, the brake lights.
06-17-2009, 12:51 PM
#9 (permalink )
is it fuse 23, a 15a?
06-17-2009, 12:56 PM
#10 (permalink )
Member Number: 7874
15 a.
06-17-2009, 12:58 PM
#11 (permalink )
The abs controller is on there too... have you disconnected that?
there is a connector after the brake switch and before all the lighting that you could disconnect to see which side of hte circuit the problem is on
06-17-2009, 01:09 PM
#12 (permalink )
Member Number: 7874
Is the abs controller in the same fuse box?
Where is the brake switch?
06-17-2009, 01:13 PM
#13 (permalink )
bake switch is by the brake pedal.
abs controller is separate, connected to the abs pump
06-17-2009, 01:30 PM
#14 (permalink )
Member Number: 7874
The wires hasn't been disconnected, ever.
06-17-2009, 01:31 PM
#15 (permalink )
no, i don't think disconnecting hte brake switch will help anything... I'm just thinking if the abs doesn't do it, there is a connector between the brake switch and the rest of the systme that you could disconnect to verify which side it's on... but there is still quite a few possibilities.
Linear Mode
» Site Navigation
> Other Vehicles
» Buyers Guide
» Network Links
