Old 11-22-2008, 10:37 PM   #1 (permalink)
minzb18's Avatar
Member Number: 67698
Default boost gauge light
i just started my car about an hour ago and realized that
my boost gauge light wasn't coming on...
how do you replace this??
minzb18 is offline   Reply With Quote
Old 11-22-2008, 10:44 PM   #2 (permalink)
srtmatty's Avatar
Member Number: 65788
gotta take the gauge off the dash, starting by taking off your pillars and taking all the screws off your dash then pop it off. then get to the gauge and it two philip screws holding it up
MOPAR MADNESS
srtmatty is offline   Reply With Quote
Old 11-23-2008, 09:03 AM   #3 (permalink)
my_little_srt's Avatar
Member Number: 41179
Trader Rating: (24)
Yea dude. Your gonna have to lift up the dash to get to the bulb. Here's a link on a how to................
HOW-TO: Replace Stock Boost Gauge w/ Aftermarket Gauge (VEI)
my_little_srt is offline   Reply With Quote
Old 11-23-2008, 10:22 AM   #4 (permalink)
fullofrage4u's Avatar
Member Number: 28533
Trader Rating: (18)
Super easy fix. Like they said. Undo the 2 Philips on each side of the dash. Then the 2 that are inside the defrosting vent ontop of the dash (they will not come all the way out but unscrew them as far as they will go.) Then take off your pillars and your dash will pry up. I found it easier to find something to prop up the dash so you can use both hands. Then there are 2 more Philips holding up the gauge pod. Once that is off you just turn and pull on the black base and pull the bulb right out of the base. I'm pretty sure it takes the same bulb that you have behind your gauge cluster. While your at it, you might as well buy some LED's and do the whole swap out. I love the way the blue dash looks. Hope this helps.
BRAVOPL POST ON HOW TO TEST FOR BOOST LEAKS:
"I'm sorry for an idiotic question. once i have this leak tester hooked up i start the car and then what? Do i just stand there and wait for some sort of whissle sound?"
SOLD
fullofrage4u is offline   Reply With Quote
Old 04-11-2009, 11:05 PM   #5 (permalink)
Member Number: 71757
can anyone post pictures on how the boost gauge takes off_
Team Inertia EPT is offline   Reply With Quote
Old 04-12-2009, 06:53 AM   #6 (permalink)
Trader Rating: (24)
Old 04-12-2009, 08:17 PM   #7 (permalink)
ahhh thankes bro for the bug help, one last question, do you need to take off the pillars in order to remove the dash?
Old 04-13-2009, 09:30 AM   #8 (permalink)
Trader Rating: (24)
Did you even read the How To????????????
Old 04-13-2009, 01:09 PM   #9 (permalink)
yea bro i did but it said to tak of the pillards but i dnt see y, idk if u have to have to, im just gona change the light to an l.e.d
Old 04-13-2009, 01:14 PM   #10 (permalink)
srtmatty's Avatar
makes it easier either way their not that hard to take off or put back on
Old 04-13-2009, 01:29 PM   #11 (permalink)
do they just snap pf or what. i dnt wanna break them
Page generated in 0.16116 seconds with 13 queries
