Old 09-26-2008, 09:23 AM   #1 (permalink)
SRT4bAngiNtUrBo's Avatar
Member Number: 21722
Default Bi Xenon HID question
Hey I ordered the 8000k Bi Xenon hid kit and I installed them last night. I go to turn on the highbeams and the headlights completely shut off.
Any suggestions to fix this or what?
Michael
2004 Red SRT-4
Mopar S1 PCM/STS/S1 Springs/S2 WGA/Drop-in Filter/Borla exhaust/Cat-delete
Forge BOV/8.5 MSD wires/PtPerformance check valve/20$ catch can/Kinetic MBC/MM inserts
SRT4bAngiNtUrBo is offline   Reply With Quote
Old 09-26-2008, 09:31 AM   #2 (permalink)
Member Number: 41718
Exclamation
I hope ur joking.... Once u install HIDs, your high beams dont work. and anyways who needs high beams once u have hids.
thuggishtavo is offline   Reply With Quote
Old 09-26-2008, 09:36 AM   #3 (permalink)
AdvanSRT-4's Avatar
Member Number: 12791
Trader Rating: (57)
Hence he said "Bi-Xenon" there low/high beams. ^
Old 09-26-2008, 09:59 AM   #4 (permalink)
by the way, they are from xenonlink.com so if anyone has these that would be a great help if you could chime in..
Old 09-26-2008, 10:17 AM   #5 (permalink)
BoostLee's Avatar
Member Number: 26266
Trader Rating: (118)
Probably need a diode going from the high to low beam wire. At least that is necessary for the HID harnesses I have for retro's.
www.realtuned.com
11 Second Club, AEM EMS, Crane 14's, 44lb/Gated/Ported/Bell-Mouthed/Anti-surged S3R
BoostLee is offline   Reply With Quote
Old 09-26-2008, 04:33 PM   #6 (permalink)
Adionik's Avatar
Member Number: 51197
Trader Rating: (25)
My Bi-xenon are giving me the same BS. The lows work fine, when I switch to the high beam they turn off. Grounds are good and everything is wired up fine...i'm not sure what the hell it is. Swapping the harnessess didn't do anything either. I think it's the ballasts.
or 16 whatev
WTB: LCA bushings
Adionik is online now   Reply With Quote
Old 09-27-2008, 12:35 PM   #7 (permalink)
haknslash's Avatar
Member Number: 21686
you MUST use have diodes. I also hope you have a proper relay harness.
Old 09-29-2008, 08:33 PM   #8 (permalink)
can you explain excatly how to fix this problem with diodes???
Old 09-30-2008, 09:09 PM   #9 (permalink)
aww sheet's Avatar
Member Number: 20431
Trader Rating: (31)
did you check your high beam fuse?
View Modifications
Old 10-07-2008, 01:00 AM   #10 (permalink)
no?.....
Page generated in 0.16202 seconds with 13 queries
