Old 12-03-2005, 05:17 PM   #1 (permalink)
lcq4blackstar's Avatar
Member Number: 33982
Trader Rating: (12)
Default ATTN: how to open up the stock head lights?
What is the best way of doing this? Dremal and cut off wheel on the glue then pry it apart?
I plan to do a light night shade coating over the crome finish to give it a black crome and upgrade to brighter lights.
Please dont reply unless positive info or a valid concern on doing this
(I.E. just buy a pair dont attempt.)
I have built custom cars and parts so this wont be hard.
lcq4blackstar is offline   Reply With Quote
Old 12-03-2005, 05:36 PM   #2 (permalink)
Member Number: 17637
Trader Rating: (12)
i think you set your oven to like 250 degrees and bake the headlights in there for like 3 minutes and it softens up the adhesive on there enough that you can gently pry the clear cover off of the housing
or im sure you could use a heat gun if you have one
2004 Black Neon SRT-4: Sold March '08
Dyno: 330hp/350tq on S2/S3 setup
2009 Waveline Pearl Scion tC: Daily driver
Stock and slow as hell!
td1042k is offline   Reply With Quote
Old 12-03-2005, 05:47 PM   #3 (permalink)
haknslash's Avatar
Member Number: 21686
Have fun melting her is all I'm gonna say.
Search and you'll find out why.
Old 12-03-2005, 06:12 PM   #4 (permalink)
Trader Rating: (12)
haknslash how would you go about doing this?
td1042k I dont think this sounds like a good idea since the housing is plastic.
Old 12-03-2005, 06:25 PM   #5 (permalink)
haknslash's Avatar
Stock ones can't be opened without possibly ruining them. Valeo (the makers of the headlight assembly) have been using a sealant that doesn't get soft under heat. Therefore, to open them up by heating them you must by DEPO oem replacement headlights. This is the ONLY way your going to open them up without cutting or hacking your housing all up to pieces.
you use the heat method just as he sujested, but it can't be applied to use on the stock units. It has to be aftermakret because they use a much more pliable sealant.
Here is my how-to. Follow it for opening up the aftermarket headlights, then modify how you wish... http://www.srtforums.com/forums/showthread.php?t=175219
Old 12-03-2005, 06:47 PM   #6 (permalink)
rhythm_neon's Avatar
Member Number: 1589
ditto. stock glue is IMPOSSIBLE to remove without damage to the headlight.
rhythm_neon is offline   Reply With Quote
Old 04-01-2007, 03:11 PM   #7 (permalink)
srt4NY's Avatar
Member Number: 47937
Trader Rating: (10)
True. i tried the oven trick and it did not work.
srt4NY is offline   Reply With Quote
Page generated in 0.14670 seconds with 13 queries
