Old 06-28-2009, 12:32 PM   #1 (permalink)
Crimsonghost's Avatar
Member Number: 72338
Default Anyone used these in a retro project?
H4 Bixenon HID projector retrofit conversion 5100K:eBay Motors (item 110378648415 end time Jul-17-09 01:44:11 PDT)
This seller is in LA, but this same kit can be found for around $150 bucks and comes with everything needed, think these would work decently mounted in stock housings?
Crimsonghost is offline   Reply With Quote
Old 06-28-2009, 12:39 PM   #2 (permalink)
here same kit, but alot cheaper price.
PROJECTOR HID XENON LEN KIT Angel Eye E46 M3 TSX H4 D2S:eBay Motors (item 110405684375 end time Jul-22-09 01:37:05 PDT)
Old 06-28-2009, 12:48 PM   #3 (permalink)
-ND4SPD-'s Avatar
Member Number: 458
Trader Rating: (46)
These are supposed to be a "bolt on" retro of sorts. Never used them so I can't comment professionally on them as far as quality output etc... I know what I think about them personally though
John Ruckman
Stage 3 with all the goodies
See My Ride
ND4SPD DESIGNS
Old 06-28-2009, 12:56 PM   #4 (permalink)
they are very appealing since they are a complete kit, However It really doesn't show what exactly holds them into the stock housings. This kit and a set of black housings would be a pretty cost effective setup if they arent junk..
I need better light output, but I don't really want a whole project to do, it would be great to buy replacement black housings, heat them up, crack them open, open up the holes a bit with dremel, show the projectors in, glue them back up and go..
Old 06-28-2009, 01:01 PM   #5 (permalink)
Plus, Bi-xenon, lows/highs is nice too.
Old 06-28-2009, 01:07 PM   #6 (permalink)
ok, I see how they work now,it looks like they are keyed and pop in just like a stock H4 bulb does, if they work like this, SWEET! but they must be pretty small at 8cm across, anything has got to be better than the stock headlights....
Old 06-28-2009, 01:14 PM   #7 (permalink)
BrandynSRT's Avatar
Member Number: 63412
Trader Rating: (24)
$100 not bad.. tell us how they come out
BrandynSRT is online now   Reply With Quote
Old 06-28-2009, 01:38 PM   #8 (permalink)
from the research i have been doing, the eyes are ccfl too.
Old 06-28-2009, 01:52 PM   #9 (permalink)
aww sheet's Avatar
Member Number: 20431
Trader Rating: (31)
i would use those for fogs only, not the main headlight just because they're so small. size does play into retrofitting headlights
View Modifications
Old 06-28-2009, 03:56 PM   #10 (permalink)
stage3matt's Avatar
Member Number: 54658
i have an old set of rear projection TV projectors I wanted to try mounting to the stock housings......
2009 1320x threads:
III
stage3matt is offline   Reply With Quote
Old 06-28-2009, 05:04 PM   #11 (permalink)
wiggyx's Avatar
Member Number: 58107
Trader Rating: (52)
Hmm, I'm curious about the output. If it's decent then these may be a really cheap means by which to get some dirt cheap retros.
Old 06-28-2009, 05:19 PM   #12 (permalink)
They do take regular 35w 6k hids, the only thing the kit dosent
include is the ballasts. So ya you basically heat up your lights,pop off the covers pop these in like mounting a bulb backwards, put covers on mount and wire, with highs/lows.
Old 06-28-2009, 05:24 PM   #13 (permalink)
wiggyx's Avatar
Trader Rating: (52)
Are you gonna pick some of these up? I'd love to hear a review from an actual forum member
Old 06-28-2009, 08:28 PM   #14 (permalink)
holy crap, check out this thread i found, this is on a FJ cruiser forum, these things have GOT to be 10 gazillion times better than Stock headlights, the install is a friggin piece of cake too!
HID Projector Retrofit Kit installation pics and video - Toyota FJ Cruiser Forum
Old 06-28-2009, 11:00 PM   #15 (permalink)
aww sheet's Avatar
Trader Rating: (31)
i stand corrected after seeing that. looks like it'll somewhat decent to use.
Page generated in 0.16164 seconds with 13 queries
