Old 10-25-2005, 05:56 PM   #1 (permalink)
wannasupra's Avatar
Member Number: 32741
Default to anyone doing led turn signals...
make sure you get the 3157 bulb with the SIDE FACING leds. otherwise you won't light up the reflector at all.
Old 10-25-2005, 06:16 PM   #2 (permalink)
Dreamert's Avatar
Member Number: 1714
Trader Rating: (51)
DOH !! mine are waiting in there little package .......
Geez should have tought about that ......ah well... which brand and whrer did you get yours ?
Dreamert is offline   Reply With Quote
Old 10-25-2005, 06:24 PM   #3 (permalink)
wannasupra's Avatar
got mine from 4headlights.com i should've thought about it before hand. oh well. super fast shipping by the way, holy crap those lights got here quick.
Old 10-25-2005, 07:01 PM   #4 (permalink)
Support@4Headlights's Avatar
Member Number: 28972
Trader Rating: (21)
Screw the reflector...take about 25 steps back from those LEDS....from the side they're lasers...LOL. You're just standing too close to see what other people see....trust me, we tried these at a local meet and thought the same thing until we got back away as if we were in another car.
Also...get down to a seated level...not standing above them...these are DIRECTIONAL...but VERY bright.
Support@4Headlights is offline   Reply With Quote
Old 10-25-2005, 07:41 PM   #5 (permalink)
wannasupra's Avatar
i'll try it tonite. if you can find any, i'd like to try a pair of the power towers, the front led's super white, the side led's blue.
Old 10-25-2005, 08:03 PM   #6 (permalink)
Trader Rating: (21)
I'll ask the manufacturer. Remember the LEDs I have are very directional...it's like the difference btween a lantern lighting a room, and a flashlight.
Old 10-25-2005, 08:31 PM   #7 (permalink)
wannasupra's Avatar
phawk those are brite. damn. could almost use those as headlights. and they look really cool with the HID's on. but they blink fast, you bastard i feel all ricey and gross...
Old 10-25-2005, 10:28 PM   #8 (permalink)
SRToc Member
Member Number: 11820
Mine should be arriving sometime this week. I got the 6ohm resistors, LED amber bumper lights and the 25-LED matrix bulbs from autolumination that have the LEDs along the sides designed to illuminate a reflector
[live]Mopar Madness[/live]
Eyeless0486 is offline   Reply With Quote
Old 10-25-2005, 10:34 PM   #9 (permalink)
SRToc Member
you can fix the fast blinking with a 6ohm resistor. takes 5 minutes to mount it correctly and uses the snap-in connectors so its VERY easy to connect.
Old 10-26-2005, 12:20 AM   #10 (permalink)
cybr's Avatar
Member Number: 31841
Trader Rating: (34)
Yea, 4headlights, the turnsignal multi-led lights I got from you aren't that bright... Wondering if you have anything brighter, with a built in resistor so my lights don't blink so fast? lol
Sponsored By: ClutchMasters, SnowPerformance, MadDog, 475hp, 468ftlb, 24psi on SAFC/Profec.
Now on the SCT - Waiting to Dyno with RaceGas + 25psi
http://myspace.com/cybr
cybr is online now   Reply With Quote
Old 10-26-2005, 03:06 AM   #11 (permalink)
SRToc Member
Member Number: 27708
any one have a diagram they wanna post up about the 6ohm resistor and where to conect it to etc. thinking about doing the leds too.
acr481 is offline   Reply With Quote
Old 10-26-2005, 05:40 AM   #12 (permalink)
Trader Rating: (21)
I don't understand the blinking fast. We put the 3157s in Hozay09's car and the 194 signals in Brian's car here at a meet (with 20 other local owners watching) and they worked normally.
Cybr....they ARE bright, I don't think you're looking at that correctly. These are a directional light so when you install them you can't view them like you would a normal bulb (I.E; standing directly above it looking down) because they don't produce an "Aura" of light. To see EXACTLY how bright they are you need to be looking at them as if you're seated in another vehicle.
Old 10-26-2005, 07:27 AM   #13 (permalink)
wannasupra's Avatar
they look really cool with the HID's on tho
Old 10-26-2005, 09:24 AM   #14 (permalink)
kotu100's Avatar
Member Number: 4357
i've had these LED corner lights that i bought from e-bay a while ago on my car. i painted the back of the LED housing blue and left the rest alone. the result: a blue non-lighting reflective housing and bright white turn signals. i've been stopped TONS of times and never once did the occifer mention the turn LED's. heres a pic for everyone.
Best run:12.167@113.93 mph with a 1.82 60'. same mods as below w/ 110octane on 24x8.5x15 MT drags.
Best Run on streets: 12.571@114.61 mph with a 2.0 60' on 18" all season tyres. mods=AGP WGA, S-AFC I, 750cc inj., HKS BOV on ATP UPP, Mopar sts, AGP dogbones, CCA FMIC, and 3" turboback no cat no mufflers.
Best MPH was 116.40 run with same mods as above!!!
Tuned by ME: 286whp 366wtq 22/13 FASTEST SRT-4 ON STREET TIRES, STOCK TURBO, OFF THE BOTTLE
kotu100 is offline   Reply With Quote
Old 10-26-2005, 11:08 AM   #15 (permalink)
SRToc Member
This is what the load resistor itself looks like. You need to be sure to mount it to a piece of metal to dissapate the heat and make sure it is not in contact with anything that will burn or melt. These things heat up like a light bulb.
As for installation, this is all there is to it. Our cars will take the 3157 bulbs since those are built to flash for our turn signals. One snap-in connector goes on the ground wire, and the other snaps into the turn signal wire.
And then you're done. Throw the LEDs into the harness and you're all set.
As for making the reflector work, most LEDs are very directional, so foward facing LEDs will do just that - throw the light foward. For information about the bulbs I bought, and why, here is the link:
Autolumination 25-LED Matrix bulb (3157)
